als ?
Old Mar 8, 2004 | 07:45 PM
Default als ?
have read about the mild als that uses a modified iscv and was curious if this can be carried out on both versions of the escos or only the large turbo version
Old Mar 8, 2004 | 08:08 PM
Billabong's Avatar
Billabong
Large turbo only as far as I'm aware, as you need a modified Weber ECU with Pectel board to run ALS (unless using certain aftermarket engine management systems)
HTH
Bill
Old Mar 8, 2004 | 10:08 PM
GARETH T's Avatar
GARETH T
second bill
Old Mar 8, 2004 | 10:10 PM
cheers was just curious to know thanks
Old Mar 8, 2004 | 11:32 PM
CossieEdd's Avatar
CossieEdd
I can't see that you'd gain a lot even if you could run ALS on a Small Turbo Escort - it's hardly a lag monster is it !
If you changed the management and went down the big turbo route though........
Old Mar 8, 2004 | 11:37 PM
not lookin' to do it just curious that was all. am lookin' into changing the management on mine etc but waiting to hear more about the secs one
Old Mar 9, 2004 | 08:39 PM
You can get mild ALS with the standard idle valve - just need the proper chip, switch, and big injectors matched. My proper ALS died and I put the stock idle valve back in. It gives mild anti-lag with this.
Tony Turbo
50
Sep 19, 2005 07:46 PM
Azrael
Jun 26, 2005 02:22 PM
Stavros
Dec 23, 2004 07:14 PM
Tony Turbo
33
Nov 22, 2004 01:36 PM
RickDraper
12
Jun 26, 2004 11:50 PM
