air injector help needed please
Old Dec 29, 2004 | 10:01 PM
the original's Avatar
the original
Default air injector help needed please
ok i just got hold of some air injectors which i would like to use with my S8
but i don't know too much about them and have some questions
i have done a search but found nothing
1. do i wire them in parallel in place of the AMAL?
2. how should i pipe them.
here is a pic, the 'jetted' red 'end cap' is on the right
does this side go to the compressor or the wastegate?
3. How much pre-load should i put on the actuator? 1/2 hole?
4. the S8 has settings for the boost control pulse width modulation of 8 Hz and 25 Hz which would be best?
5. where can i source some anodised push-on fittings to replace the shoddy plastic ones.
6. and any other stuff you can think of which might be of use...
Thank you
Old Dec 29, 2004 | 10:03 PM
the original
oh and can anyone shed any light on what i read about the mountune ones not being as good as the original ford motorsport ones?
Old Dec 31, 2004 | 02:39 PM
the original
anybody?
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Toe Knee
Aug 23, 2015 08:31 AM
Roosie
Aug 15, 2015 08:09 PM
col93saphcos
Aug 7, 2015 03:21 PM
