High revs when changing up the gears
Hi i have a fiesta 2000 X reg with the 13i ohv engine, When i change up the gearbox its reving higher than normal i cleaned out the idle valve today with carb cleaner but still the same any ideas please. So many valves to choose from these days wondered if anyone has had the same problem.
Cheers in advance
Cheers in advance
TPM961
Jan 15, 2018 10:50 AM
Adam Graham
Sep 6, 2015 06:04 AM
