Conrod specs for Focus RS and Zetec.. please
Old Nov 17, 2009 | 05:27 PM
robrs2's Avatar
robrs2
Default Conrod specs for Focus RS and Zetec.. please
Anyone got the sizes for rods in the silvertop zetec, black top and the Focus RS?
Or can Focus RS pistons fit on Standard blacktop rods?
Rob
Old Nov 21, 2009 | 09:39 PM
pdfbt40's Avatar
pdfbt40
Silvertop - 136.14mm - 20.638mm pin
Blacktop - 140.84mm - 19.000mm pin
FRS - 137.00mm - 22.000mm pin
US (inc st170) - 139.19 - 20mm pin
Generally compression height of piston matches to the rod length so as long as you use the set it works in any of the various blocks.
Martin
Old Nov 22, 2009 | 11:40 PM
robrs2's Avatar
robrs2
Right, so that means i need FRS rods to go with the FRS pistons.
Or re-bush some Silver top rods to fit.
Old Nov 26, 2009 | 01:07 AM
pdfbt40's Avatar
pdfbt40
Yep.
There aren't any bushes in standard rods. Its an interference fit on the pin.
Don't know if if silvertops can have that much taken out. I know it use to be common to bore them out for LET pistons, but IIRC thats only 21mm.
Martin
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
BRAM
Sep 8, 2015 07:11 AM
