zetec/ zvh turbo, wnat clutch for ESRT & standard box!
Old Nov 14, 2009 | 08:33 PM
Gadget's Avatar
Gadget
Spanner monkey
Default zetec/ zvh turbo, wnat clutch for ESRT & standard box!
Hi chaps, after a bit of info, got the zetec turbo here out of CliffS1's old car, it's back out of the series two again to finish some jobs we wanted to do and fit more bits to the car.
On inspection, the clutch was a bit low so we are going to replace it, it was an AP item but any serial no.s are un readable. I'm sure it's just an RST paddle clutch as the standard type gearbox is being used but just wanted to double check with people that've built them, am i right in thinking that we need the rst clutch ( still using the zetec flywheel )
cheers,
Old Nov 14, 2009 | 08:45 PM
andy130's Avatar
andy130
i fought the rst clutch,cover doesnt fit on a zetec flywheel?
Old Nov 14, 2009 | 09:00 PM
crazycage's Avatar
crazycage
the only one that works is the helix four paddle with the extra heavy duty cover .
Old Nov 14, 2009 | 09:42 PM
creator's Avatar
creator
i thought the rst were 220mm and zetecs are 240mm??
Old Nov 14, 2009 | 09:44 PM
crazycage's Avatar
crazycage
the rst and the 1.6 and 1.8 zetecs are 220mm and the mtx is 240mm.
Old Nov 14, 2009 | 09:48 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
helix do a 6 paddle aswell that are good and ian howell sells his owne spec covers that work really well
Old Nov 15, 2009 | 07:47 AM
Gadget's Avatar
Gadget
Spanner monkey
Cheers fella's, i'll get the part no off the flywheel from the owner, he has it for skimming at the mo. Then i'll call fords and get the exact model of flywheel, maybe that'd help!!
Old Nov 15, 2009 | 08:03 AM
crazycage's Avatar
crazycage
no need mate if its flat like a cvh fly then its fine
top one is cvh bottom is 240mm zetec 2.0l
neil18
Mar 14, 2016 01:08 PM
3i Jim
Nov 20, 2015 05:12 AM
matman
Sep 9, 2015 05:45 PM
druidgetafix
Aug 15, 2015 10:22 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
