S2 not holding boost
Old Mar 8, 2004 | 12:36 PM
Default S2 not holding boost
I`m after some more help
My car currently peaks at 1 bar but drops down to 0.8bar is this normal?The car will be going to get set up soon and i dont want to drive all the way up there and for the tuner to say that i need a new actuator or something.
Thanks in advance
Old Mar 8, 2004 | 01:12 PM
Standard S2 are normally only 7/8 psi. Is yours chipped? If so it could be the actuator gone a bit soft. Hope this helps.
Old Mar 8, 2004 | 01:58 PM
max boost unchipped 10psi, but heard story's of higher and supposed to be std,
your boost 1,bar then drops to o.8, in psi14.50 and 11.6psi, is about right 2.9psi,
but if running higher boost if actuator going soft u would see more of a drop, if u are using the amal valve still, disconnect wiring plug just for a test and see what boost is showing , this is the actuator pressure only,
std about 4psi, and the amal valve bleeds it off (up)
Dave,
Old Mar 9, 2004 | 04:13 PM
All sorted now thanks for your help i had the pipes the wrong way round on the amal valve.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
