mk5 erst s2 mfi conversion overfueling
hi i put erst s2 mfi engine into a mk5 escort it ran fine with the external fuel pump of the rs turbo but now i have put a uprated cosworth intank fuel pump on and its doing 15mpg it was doing double this previous to fitting new pump how can i solve this problem and why is it happening is it the higher pressure of the new pump and will a rolling road set up fix my problem my car is booked in for tuesday so i could do with nowing before then please cheers tim
my old mk5 rst ran fine with a intake cossy pump, but i was running efi, not sure if that make's any difference?
im sure if there are any problem's it'l show up on a rolling road anyway, just make them aware of a fueling problem and im sure they'll be able to sort it
failing that, join upto escortevolution.co.uk and im sure someone on there might be able to help abit more...
I would probably post this in the escort rs turbo section....
But any way, yes it is probably due to the higher output of the cosworth pump. Your MFI unit actually relies heavily on fuel pressure to do its job (it adjusts pressure depending upon mfi flap position).
Your fuel pressure regulator should in effect 'regulate' the pressure so it maybe tired.
Tell them when you get the car rolling roaded and any good tuner will adjust the fuel pressure accordingly or replace the regulator if this is indeed tired.
Good luck
Rob,
Good luck
Rob,
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
