3dr air leak
if there is an air leak somewhere in the system (its causing the revs to come down too slowly when coming off the throttle), then how do i go about finding it?
yes
also soapy water is good as it bubbles up if something is blowing
rev it up and keep your eyes peeled for something sucking or blowing
plenum to plenum cover gasket is a favourite so particular attention there
Originally Posted by Matt
yes
get your engine started and get a can of WD40 and spray it along the inlet manifold if the engine revs increase then you have a leak from the manifold gasket
ps DONT use anything else as they COULD catch fire from the dissy
Personally I use an unlit blowtorch as the revs rise when the gas goes near the hole, it's clean and very quick to find the leak. Never had any problems myself but it could be dangerous.. Just make sure you keep the gas down and it should be ok!
Originally Posted by ian m
carb cleaner is good for finding leaks and not messy like wd40. are you sure iscv isnt sticking slightly.
i might try replacing the iscv, the thing is i've already replaced it so unless i got unlucky and bought another dud one then it shoudn't be that. When its warm if you unplug it the car runs ok Thread
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
