Focus HID's
Old Nov 11, 2009 | 05:37 PM
FRS2500's Avatar
FRS2500
Default Focus HID's
wanted to know if xenon / hid headlights like these
http://cgi.ebay.co.uk/FORD-FOCUS-ST-...item3ca740bbd6 use the same connector from the wiring of the the standard headlights ie: if its a jus plug and play thing
Old Nov 11, 2009 | 06:40 PM
RichieST's Avatar
RichieST
No the plugs are different, but if you can get hold of some of the wiring loom with the plugs on the end then you can cut your original plugs off and solder the new ones on.
Old Nov 11, 2009 | 07:14 PM
FRS2500's Avatar
FRS2500
i see well would you suggest this? or am i better buying an HID kit and fitting it into the standard headlight? would the standard reflector etc resist the heat of the HID bulbs?
Old Nov 11, 2009 | 08:58 PM
RichieST's Avatar
RichieST
I had an aftermarket hid kit on an old focus, it was crap, had no beam pattern and failed the MOT. The standard xenons on my old st170 and on my new ST are excellent, i would definately try and fit a set of standard units!
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
