help me poorly old stupid mother
mother has let he automatic mondeo battery go flat in the garage
she has also parked it under the work top so cant open the bonnet
so i need to know what the deal is with autos as i know they cant be towed
can i push it back just a few inches foot maybe just so i can get bonnet open
will it cause damage?
You can safely tow an auto for a couple of miles at less than 30mph.
You will need to have a little bit left in the battery though to enable you to get the selector out of PARK, as there is a locking solenoid that is only released when Ignition is on AND foot on brake.
otherwise you may be able to charge the battery through the fag lighter socket - depends if the socket is permanently live... only use a slow charge though, or it will likely blow the fuse to the socket..
.......or there's always Pops' method
Originally Posted by gearboxman
Originally Posted by kjc300
or battery charger on to chassis earth and pos of the starter motor!!
I know Bernie!! Where is the starter motor??? Underneath!!
Even with the car on a two-poster ramp you'd have fun getting to the starter terminal, let alone crawling on the floor in a confined space
Adam Graham
Sep 6, 2015 06:04 AM
