boost spike and holding on boost controlers
Old Dec 28, 2004 | 07:40 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default boost spike and holding on boost controlers
ok can ya get a car to peak say 14psi then hold 7psi ( example) on a
amal valve,,,,,,,,,,,,,,answer is yes im guessing
air injectors,,,,,,,,,,,,,,,, answer is deffo yes as gus is hooooge proof
bleed valve,,,,,,,,,,,,,, i aint got a clue about em
manual boost controllers,,,,,, eby type thing ya see, bit like a bleed valve
electronic boost controlers ,,,,,,,,, again not sure, im asking as i got one and wondering ???
cheers for the replies and advice
Old Dec 28, 2004 | 08:13 PM
nthorpey's Avatar
nthorpey
My A'pexi AVC-R can do the spike bit as you can program a boost curve that varies with revs
Old Dec 28, 2004 | 08:16 PM
Ginge !'s Avatar
Ginge !
anyone else care to assist
the apexi avcr aint included in the as its a very trick bit of kit, tooooooo much money though for what the guy wants to spend
Old Dec 28, 2004 | 08:19 PM
Jim Galbally's Avatar
Jim Galbally
yes yes yes yes and yes
Old Dec 28, 2004 | 08:20 PM
Ginge !'s Avatar
Ginge !
oh then how ????
Old Dec 28, 2004 | 08:23 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Re: boost spike and holding on boost controlers
Originally Posted by b19bal
air injectors,,,,,,,,,,,,,,,, answer is deffo yes as gus is a hooooge poof
you nasty coont
Old Dec 28, 2004 | 08:41 PM
Ginge !'s Avatar
Ginge !
Old Dec 28, 2004 | 08:58 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Out of interest, WHY would you want it to make 14psi then hold only 7psi?
Old Dec 28, 2004 | 09:19 PM
Ginge !'s Avatar
Ginge !
was a example, nto a true setting, just to show a spike the hold
Old Dec 29, 2004 | 09:36 AM
Matt's Avatar
Matt
mines mapped with the amal cutting the boost back at high rpm to preserve the turbo a bit
as for the spike well it just spikes as much as it can briefly thats set with amal jetting (lack of) and 3/4 hole of -34 wastegate preload
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
