FOCUS 1.8 TDCI Smart charge system help!
Old Nov 4, 2009 | 01:58 PM
cossie_pol's Avatar
cossie_pol
Default FOCUS 1.8 TDCI Smart charge system help!
OK HELP!!!
have been asked to look at a friends 1.8 tdci 115ps focus,
the battery light comes on and then the car dies with apparently no juice left in the battery, so won't re-start.
Previously (about 2 months ago) the battery (silver calcium) and alternator have been changed for new items and that was fine 'til now but has died again,
after much searching on the web have found there is a common problem with the wiring on them, i've done a continuity check on the 3 wires from the alternator plug back as far as i can go on the 3 wire loom (grey/red/blue) an it all comes back as all is ok with no breaks.
have charged the battery off the car and fitted it again and it runs for a few seconds then the light pops up, and the charge in the battery is far less than it shold be,
starting to pull my hair out now and i'm thinking it's a trip to ford to be put on the machine!
any help greatly appreciated
thanks
Old Nov 4, 2009 | 05:00 PM
thebigmacmoomin's Avatar
thebigmacmoomin
I have no idea but dads old 2002 tdci 1.8 115bhp did 140k miles on the orignal battery with no problems at all.
Andy
Old Nov 9, 2009 | 09:30 PM
martysmartie's Avatar
martysmartie
The alternator is regulated by the ECU so as long as the alternator and wiring is good theres not alot you can easily do (can be checked by pulling plug on back and taking reading) , have your tried clearing KAM?
Have you checked pin 3 (Ref) this should have a live feed and is feed via a fuse
Martin
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
fuzzy
Sep 4, 2015 10:11 PM
ST-170
Sep 4, 2015 11:02 AM
