gear linkages
Old Nov 3, 2009 | 04:35 PM
bigbadbob's Avatar
bigbadbob
Default gear linkages
This has probally been discussed before but having just brought my beast I'm needing to find a way of curing the rubbish gear change. It's like an eel in a bucket. The car is a 1989 xr2 track car with a fiesta turbo engine and lsd box. Is there an alternative to a B&M quick shift?
Old Nov 6, 2009 | 04:13 PM
jayRS's Avatar
jayRS
rebuild it with new parts mate, make it crisp again
Old Nov 6, 2009 | 04:54 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
im developing one for my demo car, im extending the bottom of the selector by around 40mm, this will give a short shift effect and make the gearchange more knotchy & crisp. I will put a post up once it is done with the results
Rally designs do one for the escort which I have had 2 of, they are brill, work better than a b&m as there is no vibrations and they cost £50!!!!
its their design which ive got my ideas from
hope this helps
Old Nov 6, 2009 | 06:35 PM
bigbadbob's Avatar
bigbadbob
Thanks for the reply do you need to replace the springs and sliders inside the housing to make it work or does the kit provide for their replacement.
Old Nov 6, 2009 | 06:37 PM
bigbadbob's Avatar
bigbadbob
Thanks for the reply do you know where I can get the parts from my local ford dealer says they are no longer available.
Old Nov 6, 2009 | 07:36 PM
jayRS's Avatar
jayRS
new springs and sliders will make it feel new again.
dunno why they say they are no longer available, i have 2 kits in the shed, 1 to fit 1 for spare and i got them last year, i even got a kit for my xr2 (1985 model) so you should still be able to get them for the mk3.
but i have found some dealers say they cant get the bits but others can, might be the fact the dearler cant be arsed?? if you get stuck getting some, there are kits on ebay but there a little more expensive than ford
http://cgi.ebay.co.uk/Ford-Fiesta-Es...item439b24ecac
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
