L8 cosworth T4 500bhp chip
Old Nov 2, 2009 | 07:03 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default L8 cosworth T4 500bhp chip
A Genuine Motorsport Developments L8 chip for a ford cosworth YB (Closed loop)
spec required is as follows
83lb siemens injectors
3 bar map sensor
low comp 7.5:1
ported head
BD16 inlet/ BD14 ex cams
T4 rs500 spec turbocharger
Swedish plenum
Single air injector
std ford baby board.
closed loop control
will run the T4 at 32psi making over 500bhp on the correct engine.
£200 takes it away
also on ebay
Old Nov 3, 2009 | 10:32 PM
JTECH James
Passion for Fords!
up
Old Nov 4, 2009 | 06:21 PM
JTECH James
Passion for Fords!
uupski
Old Nov 4, 2009 | 08:07 PM
cossiedave's Avatar
cossiedave
would this need a live map to be safe
Old Nov 4, 2009 | 09:20 PM
JTECH James
Passion for Fords!
should be very close, a good fuelling and det check would deffo be needed to determine if it was safe
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
JasonPD
21
Aug 20, 2015 07:36 PM
Aug 14, 2015 07:29 AM
