my car is holding 1.78 to 1.80 bar in 4th to 5500rpm ??
Old Dec 27, 2004 | 07:51 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default my car is holding 1.78 to 1.80 bar in 4th to 5500rpm ??
should i be worried
it peaks at 1.87 to 1.88
and holds 1.79 and today was holding 1.80bar in 4th and 5th
should i be worried or not
tbh i was a bit unhappy at my rev limit so new injectors are deffo needed
but at that boost should i worry
Old Dec 27, 2004 | 07:56 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
well what fooking boost did stu set it at
Old Dec 27, 2004 | 07:59 PM
Ginge !'s Avatar
Ginge !
was set at 25 psi to hold, just wonderin if its gained boost or not
seems a logical thing to ask
i know stu was gonna turn it down asn the cams and turbo on me car make the injectors run lean after 6000rpm in 4tha dn 5th
just wondering if its normal to fluctuate
im gonna unplug the gauges as all they do is worry me, i should be looking at the road anyway
Old Dec 27, 2004 | 08:00 PM
Ginge !'s Avatar
Ginge !
i asked stu not to turn the boost down ans i dont rev the car to 6 grand and he agreed and sugested a t3, standard cams and yellow injectors for my driving
Old Dec 27, 2004 | 08:55 PM
Paul J's Avatar
Paul J
1.8bar held is 26.5~ psi. What gauge you got? Prob out compared to Stu's calibrated one.
Old Dec 27, 2004 | 08:59 PM
Ginge !'s Avatar
Ginge !
its a blitz turbo timer with digital boost gauge
also the SW gauge i got read just past 25psi
ik not in anway way doubting stus work, just wanna know is my car got a issue as i have changed a boost pipe and i have a air leak i sorted and noticed its doing this
stu had loads of stuff attached to me car when he was doing it, he even showed me stuff and i didnt understand what he was talking about, i just agreed
just incase the actuator, turbo anything could be a problem
Old Dec 27, 2004 | 09:00 PM
Ginge !'s Avatar
Ginge !
stu also did custom extra fuel in me chip too to help the higher boost issue but the tiny injectors are now the problem
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
BMROVAL
Shows & Track Days
Jul 31, 2015 05:32 PM
Graceland
Jul 31, 2015 10:34 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
