rs1800 suspension problem
Old Oct 30, 2009 | 02:08 PM
skinnerd351's Avatar
skinnerd351
Default rs1800 suspension problem
my rs1800 fiesta has gaz coilovers and recently they have started to make a knocking noise from the beam to coilovers bottom mount. i have replaced the bolt with genuine ford ones but the noise hasn't gone. anyone else had this problem. there is play in the joint as well.
Old Oct 30, 2009 | 05:24 PM
aarc's Avatar
aarc
Fiesta RST All The Way
best bet would be to take out the suspension, put the bolt through the hub tighten and refit the suspension making it a tight fit or simply check the bushes and ball joints on the side you can hear the knocking from?
Becka674
11
Oct 8, 2015 03:11 PM
L1AM_RS
Sep 23, 2015 03:27 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Brian
Sep 11, 2015 08:06 AM
truffleshuffle
Sep 10, 2015 09:35 PM
