RS1800 Head on a 2L Bottom End???
Old Dec 27, 2004 | 04:47 PM
petet's Avatar
petet
Default RS1800 Head on a 2L Bottom End???
Can I use a RS1800 Head on a Mondeo 2L Bottom End?
Old Dec 27, 2004 | 05:18 PM
SimonT's Avatar
SimonT
yes - as long as its from the same type of zetec engine
Old Dec 27, 2004 | 05:45 PM
petet's Avatar
petet
2L is from an ealy mondeo.
Was wondering if the 130 spec head and cams would be better than the 2L head?
Old Dec 28, 2004 | 05:49 PM
petet's Avatar
petet
Also any ideas on which head gasket to use - 2.0 or 1.8 (1.8 bore 80.6mm ~ 2.0 bore 84.8mm)??
Was hoping that someone would have tried this before! I assume that the 130 spec head and cams must be good because they make the 1.8 130BHP - the same as the 2.0 as standard? Would the head make the 2.0 more than 130???
Old Dec 28, 2004 | 10:48 PM
nicksaph's Avatar
nicksaph
hello mate
if you was using a 2.0 bottom end then you would use a 2.0 gasket
i belive it is more the cams and throttle body and ecu which gives the 130 spec its extra power, 2.0 is 136bhp as standard
you would proberly be better off just tuning the 2.0 with different cams, gas flowing, etc then you woulden't have problems mixing and matching componants
Old Dec 30, 2004 | 10:23 PM
richm's Avatar
richm
If the heads are interchangeable, where does the extra TDC volume come from on the 2L engine compared with the 1.8L to maintain the same 10:1 compression ratio?
dombanks
Sep 21, 2015 08:38 PM
Tank Mike
Sep 10, 2015 07:56 AM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
