Stack Programmable Fuel Level Gauge
Old Oct 27, 2009 | 09:33 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Stack Programmable Fuel Level Gauge
Stack Fuel Level Gauge. This was fitted for a few weeks only, so still looks like new.
This gauge comes with a few presets for common senders, or you can program it easily (which is what I did), by emptying then refilling the tank.
£60.
Old Oct 27, 2009 | 09:39 PM
Mark RS's Avatar
Mark RS
any chance you could email me a copy of the fitting instructions,mine needs re programed an i have lost the fitting guide.
if you dont mind i will pm you my email address
thanks.
Old Oct 28, 2009 | 01:20 AM
jon@work's Avatar
jon@work
thanks.
from here : http://www.stackltd.com/pdf/manuals_...50-1445-00.pdf
The fuel level gauge can be custom calibrated to accurately display the output
from any fuel level Sensor with an output between 0 and 270 ohms.
1. Make sure the fuel level Sensor is connected to the gauge and that the
fuel tank is empty, or nearly empty, before proceeding.
2. Press and hold the “A” button and apply power to the gauge. Keep holding
the “A” button until the dial illuminates blue (about 15 seconds).
3. Release the “A” button, the dial will move to the 1/8 tank mark indicating
the current selected Sensor (see chart below).
4. Press and hold the “B” button until the pointer sweeps to the 7/8 tank
mark. This will select the custom Sensor.
5. Remove power from the gauge to enter custom calibration mode.
6. Re-apply power to the gauge, the pointer will move to a position just below
the empty mark, indicating that the empty calibration point can be entered.
7. With an empty or nearly empty tank, capture the empty calibration point
by momentarily (less than one second) pushing the “A” button. After
approximately 1 second, the pointer will move to just above the full mark.
8. Fill the tank and momentarily (less than one second) press “B” button
to capture the full calibration point. After approximately one second, the
gauge will reset, and begin reading fuel level per the custom calibration.
9. Confirm that the gauge reads the proper fuel level.
10. If proper fuel level is not read, return to step 2 and recalibrate.
Old Oct 28, 2009 | 08:35 AM
Kelv's Avatar
Kelv
Almost there!
Same as mine, very good bit of kit and a bargain at that price
Old Oct 28, 2009 | 08:52 AM
Christian and Beccy
#1 in Spelling Club
Thanks Kelv.
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
tib2220
Sep 14, 2015 12:33 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
