What sort of psi is a 330bhp chip normally mapped to?
Old Dec 27, 2004 | 12:35 PM
Default What sort of psi is a 330bhp chip normally mapped to?
I know this is probably a pointless question as no doubt it varies depending on who you get the chip off, but just wondered what it should be mapped to, had a go at running my car at 2 bar yesterday and it seemed perfectly happy, no pinking or anything and it went like snot, but just wondered if this is likely to be off the end of my "330 bhp" chip or not?
Old Dec 27, 2004 | 12:40 PM
kjc300's Avatar
kjc300
22 So stop it now!!!
Old Dec 27, 2004 | 12:41 PM
gurnE's Avatar
gurnE
2 bar on greens
Most off the shelf stage 3 chips are between 21 & 24psi
Not 30
Old Dec 27, 2004 | 12:42 PM
GARETH T's Avatar
GARETH T
it went like fuck,, because it was lean as anything
Old Dec 27, 2004 | 12:43 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
most people run between 21 to 26psi ish on a green conversion
but as you said,all cars/chips are different
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
i was going to say about 25psi
Old Dec 27, 2004 | 12:44 PM
I wound the fuel pressure up a load to compensate, lol
I only took it up to about 4500rpm or so and only in short bursts, was just interested to see how it handled it.
I know the risks i was running potentially, but i am just about to fit a new turbo, new head gakset and new head studs anyway so figured i didnt have a lot to lose.
I'll behave from now on though, lol
I was well impressed at how well it seemed to handle it though, but i guess -1 degrees outside temp is a good way to avoid det.
Old Dec 27, 2004 | 12:50 PM
Rene's Avatar
Rene
you can loose you complete bottom end by doing that!
i know coz i did the same thing ... turbo was fine bottom end was scrap
Old Dec 27, 2004 | 12:52 PM
yeah i know, hence i kept it in short bursts only to prevent heat building up in the pistons.
im really not advising anyone to go and do the same on their 330 chip
Old Dec 27, 2004 | 12:55 PM
JamesH's Avatar
JamesH
Old Dec 27, 2004 | 01:01 PM
flashpoint's Avatar
flashpoint
If you’re not very careful, it all ends in tears
Steve
Old Dec 27, 2004 | 01:04 PM
Stu @ M Developments's Avatar
PassionFords Creator
Afternoon Chip,
Generally speaking, at std fuel line pressure a std T3 turbo on a YB will maintain a decent AFR at up to 24psi held to the limiter. A T3 map tails the fuel off from 5k as the peak efficiency envelope has been passed with that turbo and the power drops off, so this is your danger area with too much boost. A T34 or larger will obviously drop this boost figure slightly whilst making more power. A real T34 map also wont start to lean at 5K as the peak power is now higher.
On my own T3 std YB chips i recommend the boost be set to peak at around 25 and hold around 22.This gives a good air fuel ratio margin and helps to control ACT's on the std intercoolers. Merry Xmas.
Old Dec 27, 2004 | 01:05 PM
lol, relax everyone, car got a few bursts of not more than 5 seconds and is now back down to a sensible level.
i was just curious at how far it was likely to be mapped simply cause it seemed to run so well.
Old Dec 27, 2004 | 01:06 PM
Originally Posted by Stu @ M Developments
Afternoon Chip,
Generally speaking, at std fuel line pressure a std T3 turbo on a YB will maintain a decent AFR at up to 24psi held to the limiter. A T3 map tails the fuel off from 5k as the efficience envelope has been passed and the power drops off, so this is your danger area with too much boost. A T34 or larger will obviously drop this boost figure slightly whilst making mnore power. A real T34 map also wont start to lean at 5K as the peak power is now higher.
On my own T3 std YB chips i recomend the boost be set to peak at around 25 and hold around 22.This gives a good fuel margin and helps to control ACT's on the std intercoolers. Merry Xmas.
Perfect mate thats the sort of info that i was after.
If i get you to do me a live mapped chip what sort of boost can i run then on greens and a t34?
Hopefully wont need anything like 30psi to make good power on that turbo!
Old Dec 27, 2004 | 01:13 PM
By the way, in case anyone was wondering why i was even bothering doing this, im intending to use the old turbo on my 2.0 16v turbo mini as it should be ideal for that as i dont need much over 300bhp off nitrous as it will be so rare i have the need to run any more power than that due to the weight of the car (600kgs ish)
So just wanted to see what the turbo was capable of, pretty impressed to be honest!
Old Dec 27, 2004 | 01:17 PM
Rene's Avatar
Rene
old decent build quality
Old Dec 27, 2004 | 01:20 PM
Cant fault cossie bits to be fair, they are MUCH better than a calibra turbo
Old Dec 27, 2004 | 01:24 PM
Phil's Avatar
Phil
Jeebus
Come on chip, you of all people should kjnow its pointless screwing a tiny turbo to bursting point from a power point of view! It will probably be just as quick at the proper boost and fuelling setup!
Old Dec 27, 2004 | 01:27 PM
phil i know mate!
ive just bought a t34 for it, i was just purely seeing what i could get out of the old one to know if it was good enough for the mini or not, as that will only ever be used in short bursts anyway, and this way i have a turbo FOC that i can use, and if it isnt good enough can always upgrade to a t34 on the mini too once i have the manifold etc to suit.
like i said i am NOT recomending anyone do the same!
A.t.p
Sep 29, 2015 05:04 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
