XMAS pressie - cone filter - now what ? 4x4 cossie...
Old Dec 27, 2004 | 12:15 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default XMAS pressie - cone filter - now what ? 4x4 cossie...
Mrs frog got me a cone filter for christmas, now that I have to fit it on a 4x4 cossie, I have a few questions:
-There is a pipe to the air box from the Amal valve, what do I do with it ?
-If I want to take the standard d/v off while I am there, do I just take it off, bung the hose that goes into the intercooler and the hole in hose that feeds the turbo ?
-Also, what do I do with the pipe that comes off the inlet manifold and terminates on the d/v ?
Many thanks
Greg
Old Dec 27, 2004 | 02:12 PM
wimwerf's Avatar
wimwerf
the pipe from the airbox to the amalvalve can go in the bin
as for the holes on the inlet hose from airbox to turbo you need a blank thing to close it. for the connection on the IC the same....
the vacuum pipe from the inlet to the dv you can put a screw in or remove it or something...but you have to close it..
good luck
Old Dec 27, 2004 | 10:23 PM
frog's Avatar
frog
Thanks winwerf, that makes sense - prob try tomorrow...
Old Dec 27, 2004 | 10:41 PM
wimwerf's Avatar
wimwerf
good luck
Old Dec 28, 2004 | 11:47 PM
Daveyraveygravy's Avatar
Daveyraveygravy
it will chatter like a biatch with that on there now
Old Dec 29, 2004 | 12:07 AM
frog's Avatar
frog
Even with an ickle T3 ???
Old Dec 29, 2004 | 12:36 AM
rapidcossie's Avatar
rapidcossie
make sure you have plenty cold air ducting or you could lose power from drawing in hot air from the engine bay...
Old Dec 29, 2004 | 10:18 AM
frog's Avatar
frog
Yup ! Got lots of ducting...
Old Dec 29, 2004 | 10:54 AM
MrsFrog's Avatar
MrsFrog
The Frogs latest conversation:
Frog Going to install the new filter on the car. Want to come and help?
MrsFrog I don't mind ... but I don't know what I could help you with.... it's not like there is a lot of space to work around...
Frog You could always screw some things while I watch....
I am still shocked....
Old Dec 29, 2004 | 11:45 AM
Nath's Avatar
Nath
Old Dec 29, 2004 | 03:02 PM
frog's Avatar
frog
Old Dec 29, 2004 | 04:19 PM
wimwerf's Avatar
wimwerf
with a t-3 and 23psi without a dv and a cone filter it will chatter like fook
Old Dec 30, 2004 | 02:10 PM
frog's Avatar
frog
wimwerf, it's a T3 with 15 psi (only stage 1), and still chatters like fook as you say, even driving around town when not driving hard, but it's quite a deep chatter, not like MrsFrog's T34 which is high pitch
Car seems so much more responsive, not sure if that's the cone or the fact there's no dv, but it flies.
And I found the cause of my misfire - dodgy spark plug in no 1. All sorted with a spare, just need to get me a new set of NGK's.
Thanks again for the help.
Greg
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
