Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Engine conversion question
Old Oct 22, 2009 | 06:31 PM
Laner's Avatar
Laner
Default Engine conversion question
Ok peoples, i know they aint exactly the nicest cars in the world but i've got a mk2 orion or onion whichever you want to call them.
1.6 cvh carb, only 72k but stem seals have gone and carb needs attention so i've decided to bin the lot and go a (little) bit more modern so i've decided i want a zetec. Obviously this entails alot of work but i'm going to keep with some older ideas etc..
so plans are (as i'm on a budget) 2.0 mondeo lump, bike carbs on either homemade or if a cheap enough on appears bogg brother manifold and simple edis spark system.
Now i know the basics like using the 1.8 sump, oil pickup, cvh oil filter....
Here comes the tricky questions i can't find out in alot of places, can i still use the 1.8 zetec flywheel and clutch assembly with the 1.6 cvh box and will this be ok to run the edis from the crank sensor?
i dont want to spend a fortune on this car but would like to be have something quiet quick and be able to transfer the engine out to something else at a later date.
Thanks in advance.
Laner
Old Oct 24, 2009 | 08:37 AM
I would put this question in the technical section, gets more viewers there.
Old Oct 24, 2009 | 08:50 AM
rs_turbo_tony's Avatar
rs_turbo_tony
yes you can use flywheel and pick up sensor on zetec are you doing zvh or 16 v double over head cam also i would use twin 45s webers, bike carbs are not very good really and you can pick 40s or 45s same price
Old Oct 24, 2009 | 12:04 PM
Laner's Avatar
Laner
yea i've noticed that sinced i looked into it bout 12 months ago the price of bike carbs are shooting up and webbers have fallen...
Nah full 16v conversion, dont like cvh to be fair except the rst ones ofcourse which was my engine of choice but i would need a complete rst which would be too much if i'm honest.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Caddyshack
Aug 19, 2015 07:29 PM
