Changing a sump on escort cosworth
Old Oct 22, 2009 | 05:17 AM
fordrallycar's Avatar
fordrallycar
Default Changing a sump on escort cosworth
Hi all iam thinking about changing to a big winged sump on my escort cosworth Iam reasonable with the spanners is a job i could do in the garage or is it a nightmare???
any tips or suggestions would be great
Cheers Paul
Old Oct 22, 2009 | 05:20 AM
rubinsbin's Avatar
rubinsbin
For road use!
Old Oct 22, 2009 | 05:38 AM
fordrallycar
Iam thinking about some trackdays & road use
Old Oct 22, 2009 | 07:25 AM
dojj's Avatar
dojj
Resident Wrestling Legend
need 2 drop the xmember, easier said than done. Good luck. U may need mates 2 help
Old Oct 22, 2009 | 07:31 AM
rog's Avatar
rog
As above, I'd only get one for track use, as well as a hole host of other things, but if you want to change the sump yourself, you have to drop/move the crossmember or lift up the engine it WON'T come out by simply unbolting the sump, the only way i have ever managed to do this is cutting the pickup pipe off with a hacksaw to get it past.
Old Oct 22, 2009 | 07:55 AM
dojj's Avatar
dojj
pick up pipe goes around the intermediate shaft and is a bit of a git to get out in situ
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
