pf plumbers
Old Oct 21, 2009 | 08:29 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default pf plumbers
simple question
had a double sink
now got a single sink
the pipes were blocked off
now they are cloging up
just want to change one pipe
but can't
no one will sell the elbow i want on it's own
can anyone help?
the pipe on the right is connected
the ones on the left and the middle are blocked off
all i need is an elbow from the right hand pipe to the u-bend, but all the ones i can find singularly have the bigger fitting/thread on them even though they are all labeled 40mm
apparently i need a 32mm kit, but no one does it other than in a kit, and i don't want to fork out £20 odd for a kit when the elbows can be had for £2 (albit it the wrong ones )
where can i go to find one?
Old Oct 21, 2009 | 08:31 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Are you trying a proper Plumbers Merchant or a DIY store?
Old Oct 21, 2009 | 08:35 PM
dojj's Avatar
dojj
diy stores at first
plumbigng stores tomorrow
if they are available seperatly
Old Oct 21, 2009 | 08:45 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
why dont you just get rid of all the other pipe work and put the trap straight on the waste on your single sink? then alter the pipe slightly to suit?
40mm is 1 1/2 inch what you use for sinks, you use 32mm for stuff like hand basins.
Old Oct 21, 2009 | 09:05 PM
focusv8's Avatar
focusv8
You don't need any "Special" bends.
Use a standard compression elbow either 32mm or 40mm whichever is the correct size.
The pipe on the right is a slide fit into the centre cross (adjusts for different sink sizes), fit the standard elbow straight onto the end of that.
The "J" piece of the trap will either have a tapered seal on the top or a collar that you can cut off then fit the other end of the Standard elbow onto there.
Old Oct 21, 2009 | 10:13 PM
dingla rs's Avatar
dingla rs
buy ur self a single sink trap bout 4 pound from builder center no bodge job then 40mm 1inch/half fitting
Old Oct 22, 2009 | 03:37 PM
focusv8's Avatar
focusv8
2 reason's why he shouldn't;
It's £2 more than he wants to spend.
The height between the sink outlet and the trap outlet will be different, even if it's an adjustable one, and he'll be on here for the next 6 weeks asking how to stop the leak.
Old Oct 22, 2009 | 04:21 PM
dingla rs's Avatar
dingla rs
dovboy
23
Jun 20, 2008 09:59 PM
Christian and Beccy
13
May 6, 2006 09:50 PM
Fiecos Dan
May 1, 2006 08:25 PM
