Box located under o/s/f wing 4x4 sapphire
Old Oct 21, 2009 | 07:05 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default Box located under o/s/f wing 4x4 sapphire
does any one no what this is and where the vacume runs to that comes off of it and runs through a solinoid
cheers
Old Oct 21, 2009 | 07:10 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Charcoal cannister filter for emissions control
Old Oct 21, 2009 | 07:12 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
yes, runs through the purge vave, which in turn connects to the plenum
Old Oct 21, 2009 | 07:13 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Which in turn is usually disconnected
ASHCOSSIE's Avatar
ASHCOSSIE
so it should be connected then
Old Oct 21, 2009 | 09:02 PM
ASHCOSSIE's Avatar
ASHCOSSIE
how does this work by the way ?
Old Oct 21, 2009 | 09:07 PM
JTECH James
Passion for Fords!
the canister absorbs fuel vapours when the car is switched off, these vapours are burnt when the engine is fired up as they are fed into the plenum
doesnt really matter if its disconnected
jason_nike
Aug 18, 2019 10:53 AM
jdsjojo
PassionFord Swap Shop.
Aug 26, 2015 09:51 PM
borboyous
Aug 22, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
