Fuel Pressure Reg WARNING!
Old Oct 20, 2009 | 06:35 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default Fuel Pressure Reg WARNING!
In the last week alone i have had two cossies in with nice shiney ebay purchased fuel pressure regulators fitted,
interestingly both cars also had seriously dangerous afr on boost.
the answer.The fuel pressure regs do not correctly increase pressure when boost is applied to them!
this is becomming more and more common with the spurt of cheap regs being sold for peanuts on ebay, so i thought i would give you a heads up which may save at least one of you an engine
they dont work guys, buy the real deal, they are cheap for good reason!
Old Oct 20, 2009 | 06:42 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I remember a spate of these a few years ago when I had my last Cossie James - a few melted engines later and people stopped using them for a while
Old Oct 20, 2009 | 06:43 PM
JTECH James
Passion for Fords!
it seems they are back!
Old Oct 20, 2009 | 06:44 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
fse power boost valves?
Old Oct 20, 2009 | 06:47 PM
JTECH James
Passion for Fords!
not that brand,
one was a copy aeromotive,
Old Oct 20, 2009 | 06:48 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Yea the FSE FPR seemed to get a poor write up a while back... a couple Subarus up here went tits up due to these.
Cheers,
Grant
Old Oct 20, 2009 | 06:49 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
No, they are very similar to the Aeromotive items. Red anodised and polished aluminium finish. They don't have the aeromotive logo on them and having tested one myself with a 2 bar reference pressure into the vacuum nipple, we only saw a 0.5 bar increase in fuel pressure.
The standard weber item increases fuel in a 1:1 ratio, so for every 1psi of boost pressure in the inlet manifold, the regulator increases the base fuel pressure by 1psi.
The reason for this is to overcome the differential pressure caused by the positive pressure in the inlet manifold resisting the fuel exiting the injectors.
The two cars we've seen have both been lean enough to melt!!!
Old Oct 20, 2009 | 06:53 PM
JTECH James
Passion for Fords!
pikeymotive
Old Oct 20, 2009 | 06:57 PM
sbd16v's Avatar
sbd16v
is the problem because they do not rise at the same level as your chips expect it to ??
or they are just not rising at all when on boost
Old Oct 20, 2009 | 07:00 PM
Sonic Boom's Avatar
Sonic Boom
Is it one of these:
http://cgi.ebay.co.uk/AEROMOTIVE-STY...item1c0d311ef8
Rich
Big Will_'s Avatar
Big Will_
Barely rising AT ALL.
As said, when i went from atmospheric pressure to 30psi in 2psi intervals while testing one, the increments in pressure were minimal. I saw a 7psi increase with 30psi fed into the reference nipple. That 7psi should have been 30...
JTECH James
Passion for Fords!
the one i had in today did raise rate, but the rate was not fixed, it was all over the place
the one will is talking about didnt raise 1-1 which is whats needed on a yb it was way under pressure on boost
Old Oct 20, 2009 | 07:02 PM
Big Will_'s Avatar
Big Will_
Originally Posted by Sonic Boom
It would be unprofessional of me to say that it is that exact one, however, it did look very similar and the fact the advert states it is an aeromotive COPY would concern me.
I'd avoid taking chances and melting my engine and buy the genuine thing. Might be Ł100 more, but its a whole lot cheaper than an engine rebuild!
Old Oct 20, 2009 | 07:11 PM
JTECH James
Passion for Fords!
the other thing to think about is the people that have fitted these, but they are working in some fashion at the moment...i have no doubt lots of people are using them,
the next time you come on boost will it work? or will you melt your engine? its a risky game having them on any turbocharged/supercharged engine imo, the next squeeze onto boost may be the last
Old Oct 20, 2009 | 08:04 PM
st3v3's Avatar
st3v3
i think thats a good Passion Ford TopTip
Old Oct 20, 2009 | 08:34 PM
Mike1's Avatar
Mike1
Can you buy the genuine ones though at the moment ? I seem to recall people having difficulty getting hold of them a few weeks back?
Old Oct 20, 2009 | 08:36 PM
JTECH James
Passion for Fords!
a genuine aeromotive, sard or the like will be fine if the ford ones are hard to get...
Old Oct 20, 2009 | 08:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how do you test them?
i have an xs-power one that looks identical to that, its a few years old tho.
fit a bicycle pump to the brass nipple and pump it up?
i have a guage fitted to mine and it does get 1 bar when cranking, but the engine doesnt run to find out any more.
Moonstone Steve.'s Avatar
Moonstone Steve.
James , which type do i have hun.
Steve
Old Oct 20, 2009 | 08:42 PM
JTECH James
Passion for Fords!
Steve
you have the real one, the one the pikeys are trying to copy...badly lol
i would never buy shite!
Old Oct 20, 2009 | 08:46 PM
JTECH James
Passion for Fords!
the one i had in today also had a gauge....which was juat as inaccuate as the reg
to test it simply run it at a set base pressure, ie 3.5bar, pipe off,
then apply a caliberated amount of pressure to the reference nipple,ie 1 bar
the fuel pressure should raise 1:1, so in this example it would be 4.5 bar
make sure you use a caliberated fuel pressure gauge... not the one supplied on the reg!
Old Oct 20, 2009 | 08:48 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the engine doesnt run yet
is there a way of testing without it running?
Old Oct 20, 2009 | 08:49 PM
Moonstone Steve.
Steve
Old Oct 20, 2009 | 08:51 PM
JTECH James
Passion for Fords!
im sure you could find a way lol
if you can run your pump then you can base test it
Old Oct 20, 2009 | 08:55 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yes i can run the pump, but then i cant get an accurate measure of the extra bar of air to put in. i have an old bicycle pump but fook knows how accurate that is
Old Oct 20, 2009 | 08:58 PM
andy130's Avatar
andy130
do u sale the proper one james?
JTECH James
Passion for Fords!
bike pump, i can just see you pumping away
you need an accurate air supply of some type, otherwise the test is pointless,
Old Oct 20, 2009 | 08:59 PM
JTECH James
Passion for Fords!
the std ford fitment one?
Old Oct 20, 2009 | 09:01 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ill try and set the compressor to a bar then, dont know if it will go that low tho.
cheers for the help james
Old Oct 20, 2009 | 09:03 PM
james kiely's Avatar
james kiely
good info james ,cheers
cheers james
Old Oct 20, 2009 | 09:05 PM
JTECH James
Passion for Fords!
no probs,
its a good test if you can increase the boost pressure from 0 through to 2 or even 3 bar, then you can see just how accuratly the reg raises rate...or not lol
you can imagen our reaction when we tested one through to 2 bar boost and it only raised rate by 0.3 or so
Old Oct 20, 2009 | 09:08 PM
Big Will_'s Avatar
Big Will_
no probs,
It wasn't particularly repeatable on a family forum James...
Old Oct 20, 2009 | 09:17 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
heres a real aeromotive reg with no fitting included
, you can hardly tell the difference but the price says something being Ł90 cheaper with fittings and braided fuel hoses . mine cost around Ł170 from webster race engines
Old Oct 20, 2009 | 09:22 PM
Big Will_'s Avatar
Big Will_
Webster Race Engineering only sell genuine Aeromotive. It's where all of my Aeromotive fuel system came from!
Old Oct 20, 2009 | 09:37 PM
fraser9764's Avatar
fraser9764
how about one of these cheapies on a n/a engine though? what is the fuel pressure supposed to do on a n/a engine throughout the rev range?
Old Oct 20, 2009 | 09:38 PM
Big Will_'s Avatar
Big Will_
Reference vaccum and atmospheric pressure.
I didn't test it's vacuum properties - the rising rate under boost was the concerning factor!
Old Oct 20, 2009 | 11:49 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Fucking scary ... Good bit of info
Old Oct 20, 2009 | 11:54 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its scarey the things people try and save money on sometimes.
Secondhand 2wd reg for 30 quid or whatever is the way to go if you must save money on such an important thing.
How anyone can think a cheap copy regulator is an "upgrade" from the standard one just cause its more shiney is beyond me, lol
Old Oct 20, 2009 | 11:56 PM
Chip's Avatar
Chip
The differential is meant to stay the same, so effectively when the pressure doesnt rise the differential drops.
It WOULD be possible to map round it, but you'd need fecking massive injectors and the spray pattern would be compromised.
Then if it changes, which lets face it on something so poorly made its likely to, its then game over anyway of course!
Old Oct 21, 2009 | 02:10 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
because people are stupid and think "aeromotive style" will mean it actually works rather than looks shiney.
does seem pretty dumb to cut back on something so engine safety critical!!
