Full Beam problem (Help)
Old Oct 18, 2009 | 03:51 PM
Ridgey's Avatar
Ridgey
Default Full Beam problem (Help)
I have a dodgy headlamp hope someone can help.
This happens to ONE of my headlamps:
Side light is OK
Head lamp is OK
Full Beam .... whole headlamp goes off.
This is when the the indicator stick is pulled back to flash the full beam as well as push it forward to switch the full beam on.
Other side works fine.
Any ideas
cheers
Old Oct 18, 2009 | 04:06 PM
j6kyt's Avatar
j6kyt
sounds like an earth problem to me mate
Old Oct 18, 2009 | 06:36 PM
Ridgey's Avatar
Ridgey
I'll check, any other possibilities ?
Old Oct 18, 2009 | 07:28 PM
Earth problem, but clean up both sides, located behind each headlight.
If you want better lights for free, run a new earth direct from battery to the headlights, insides NOT the connector.
I upgraded mine with a relay in each for dip and one in each for main beam, then seperate live earth wires, so much better!!
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Rod-Tarry
237
Mar 18, 2016 09:13 PM
Oct 9, 2015 07:38 PM
FlashRS
Sep 14, 2015 12:36 PM
