boost trouble *UPDATE*
Old Oct 18, 2009 | 11:14 AM
2wdsaff's Avatar
2wdsaff
Default boost trouble *UPDATE*
my saff has "stage 3" parts on it, jut fitted a boost guage into it and its peaking 0.5 bar holding 0.4 bar.... im sure 0.8 is standard???? i tried adjusting the actuator up but it doe not make any difference... could my amal valve be blocked? or even standard?
Old Oct 18, 2009 | 12:53 PM
oldford's Avatar
oldford
Or the boost gauge is defective.
Is the amal valve clicking when you disconnect and connect the electrical wires?
Old Oct 18, 2009 | 06:09 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
remove the amal out of the loop ad pipe actuator directly from the turbo compressor housing.
see if it makes any difference.
if not, it's the actuator spring.
Old Oct 18, 2009 | 06:10 PM
2wdsaff's Avatar
2wdsaff
boost gauge works perfectly, car does not feel fast atall, my golf gttdi150 spanks all over it!!!
amal valve is clicking yes....
Old Oct 18, 2009 | 06:11 PM
2wdsaff's Avatar
2wdsaff
tried that and its just the same, take it my actuator is duff?
Old Oct 23, 2009 | 08:36 AM
2wdsaff's Avatar
2wdsaff
tried another actuator on and its slightly lower now, peaking and holding 0.4 bar.....could it be a boost leak when its getting to 0.5bar?
Old Oct 23, 2009 | 10:52 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Check all the vacume pipe's. My m8 had this problem on his rst and it was only pushing out 90bhp cos of the leaking hose. And check to see if you have kinked the pipe too when fiddling with it
Old Oct 23, 2009 | 11:15 AM
rog's Avatar
rog
Could be any manner of things chap, my first thought when i read your first post was the Actuator, but you say you've already eliminated that. Can you give us a bit of history on the car, did you buy it recently with those bits fitted, or have you had the car for a while and fitted those bits, did it ever feel faster and seem to boost more???
What i do to set the actuator is get a foot pump and a connector, plug it into the hose and set the load on the wastgate to see when it starts moving, that way you know that it's set correct. Failing that, it could be an air leak or a duff turbo that just can put out the correct boost. From experience the car with a stage 3 chip should safely be able to boost around 1.5bar and upwards if you really get bored and fancy your chances, if the fuelling has been set etc..
I'd check all your hoses/clamps and intercooler for anything obvious.
Old Oct 23, 2009 | 01:28 PM
2wdsaff's Avatar
2wdsaff
i brought the car just recently with all the parts fitted, however the guy has had the engine out etc and it had been lying for 6 years then he put it all back together and i brought it like this.. is there anyway of checking the boost pipes for leaks by pressure testing the system somewhow? turbo was recon before it came off the road and worked perfect then he reckoned? i reckon both the actuators i've tried are standard ones though, will that make a difference?
Old Oct 23, 2009 | 05:47 PM
forevaford's Avatar
forevaford
put a dash 34 actuator on it that will do the trick
Old Oct 24, 2009 | 09:59 AM
2wdsaff's Avatar
2wdsaff
yea dont think its quite as simple as that sadly....ha ha
Old Oct 25, 2009 | 10:25 AM
gingerturbo
Even if there standard it should still run about .8. It does sound like a leak unless the setup is all wrong
Old Nov 4, 2009 | 02:40 PM
2wdsaff's Avatar
2wdsaff
*UPDATE* just pulled the downpipe off and turns out the penny washer is not sealing in the exhaust housing....... is this fixable or is it new turbo time???? im so p****d off with this car its unreal! damn cosworths!!!!!
Old Nov 4, 2009 | 03:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
hold on fella, you just need a new turbo exhaust housing.
or someone to rectify the one you have.
easy to change if you've got a spanner, vice, hammer and lots of patience.
you can do it yourself if you find a housing, maybe choose one that is best for how you want yours to run too.
shouldn't be more than £30-50 i wouldn't have thought for a standard 0.48 one.
Old Nov 4, 2009 | 03:59 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
just had a look on the bay and a new one can be had for £200, which isn't too bad, but there must be someone around with a knackered t3 on a shelf woth a housign in good nick.
maybe try a turbo place and they may have one sat around
or get this one when it finishes for next to nothing:
http://cgi.ebay.co.uk/COSWORTH-T03-T...item414a3fc8b5
Old Nov 4, 2009 | 05:05 PM
2wdsaff's Avatar
2wdsaff
cheers xr2wishy,
so its just the housing i need? would a turbo refurbishers be able to sort it?
Old Nov 5, 2009 | 09:20 AM
gingerturbo
Yeh they should be able to. It will probily cost around the same
Old Nov 5, 2009 | 07:41 PM
2wdsaff's Avatar
2wdsaff
how do you mean cost the same?
think it would be an idea to get a refurbished complete turbo as my one is just a standard turbo anyway with slight play...
Old Nov 5, 2009 | 08:33 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if yours has a bit of play that's fine as long as there is no smoke from the unit.
if it is a bit smokey, then get it off for reconditioning, may as well chuck in a 360degree bearing too.
but, you may consider getting a 4wd cossie turbo unit as these can boost more from standard
Old Nov 6, 2009 | 06:28 PM
martysmartie's Avatar
martysmartie
These have been repaired before but if you say your turbo has play it may be an idea to consider a rebuild.
Martin
Old Nov 8, 2009 | 11:24 AM
2wdsaff's Avatar
2wdsaff
the play in the turbo is just sideways and its minimal, found a recipt for a rebuild 2500 miles ago also, wastegates now fixed also, i replaced the ceramic bush that wastegate pin turns on. now thats good, however i still can only get 0.5bar..... now i checked both actuators with a foot pump and turns out they both start to open at 6/7psi...... that'll be my 0.5bar then.... so whats next? new actuator at least?
Old Nov 8, 2009 | 11:42 AM
JamesH's Avatar
JamesH
Fit a new -31 actuator
Old Nov 8, 2009 | 05:50 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, or get a -34 if you plan on much more in the future.
Old Nov 12, 2009 | 01:56 PM
2wdsaff's Avatar
2wdsaff
just got a lend of a brand new -31 and its a completely different car at standard boost!!! would it be best to go for a -34 as i'd like to be able to run 1 and 1.5bar boost when i get it setup
Old Nov 12, 2009 | 02:18 PM
rog's Avatar
rog
It should run 1.5 bar on a -31 no problem.
Old Nov 12, 2009 | 06:59 PM
2wdsaff's Avatar
2wdsaff
perfect ill go for one of them, cheers rog
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
