could any one answer this one ??
Old Oct 17, 2009 | 06:59 PM
anfy's Avatar
anfy
Question could any one answer this one ??
hey i was woundering on the side of my t3 turbo pressure housing there is what looks to be a bleed pipe which goes to the amal valve then to the actuator should this be giving any pressure or have suction or do nothing ?? cheers any one
Old Oct 18, 2009 | 01:25 PM
anfy's Avatar
anfy
btttttttt any one??
Old Oct 18, 2009 | 01:38 PM
nellyscossy's Avatar
nellyscossy
that pipe will have boost pressure
the boost pressure opens the actuator via the amal valve which acts as a "bleed valve" controling boost depending on what the ecu tells it
Old Oct 18, 2009 | 01:51 PM
anfy's Avatar
anfy
so would it give pressure out when just on tick over or when its up in the rev range??
Old Oct 18, 2009 | 07:05 PM
It will show a vacuum at idle, but will go positive(pressure) when boosting.
At idle the turbo is not really doing anything other than revolving really slowly, so the engine is sucking, once above a certain point the air pump(turbo) comes in, so it no longer sucks but is fed with pressure.
Fiddy
21
Sep 29, 2015 06:10 PM
rsguy
44
Sep 29, 2015 03:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
