Steve MK2 XR2 Turbo project updates 30-10-09
This is my MK2 XR2 Turbo project
At the moment I'm replacing/renewing some of the panels on the XR2 to make it mint before I put in the RST engine and running gear etc. I'm also gonna make a few upgrades here and there and a few choice mods (nothing too mad) for now and it should be done sometime just after new year 2010.
Heres some pics on the project. I will post more up as my project evolves. Thanks for looking
try fit the engine and bits the engine is still the XR2 one lol
now the front all a part
now cutting the rust out and putting now inner wings on
in primed
try fit with the new front mount
the engine
modifying the bonnet hinges.
the bonnet and the bits of wood are only templates
I rolled the lips over on the front wings and i've 2K primed the inside of the wings and front panel etc...
croosmember welded and on the car and the front welded up
had to cut the chassis leg because the tie bar bracket bolt snapped
croosmember all welded up and the front sealed & stone chip
the bonnet brackets are made and welded
more soon
Thanks for looking
what do you guys think ?
in primed
the engine
more soon
Thanks for looking
cheers for the replies
ive gotta try fit the engine so i can make the brackets up and finish off the front panel, then i will be starting on the back of the car and get the whole shell in primer and roll it up on its side and start the underneath etc etc.
iv got my new fans from rally design on monday, thay are Revotec 6.6" thay fit relly nice now a can get bak on the car now
iv got the intercooler in place so now i can make the brackets up
its not a 03reg lol
also just brough a stage 1 head with a kent cam kit 35 cam at a bargain 140
its not a 03reg lol
seein that i renewed most of the front end, well iv find some bad welding on the bad of the car now so now im going to renew the rear wings, sills and the inner rear wheel archs the back panel is good
pics \/
now iv got some work cut out for me
pics \/
nice to see an xr2 getting tlc had 1 myself needing same amount of work but never did it cuz i was 17 so i got 1 out of the scrappy and used that shell its a shame you cant do that anymore. tons of
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
