sierra p100 injection
Old Oct 16, 2009 | 08:09 PM
johnnysash's Avatar
johnnysash
Default sierra p100 injection
anyone know the best way of getting a swirl pot and fuel pump onto a carb sierra p100 pick up
Old Oct 17, 2009 | 01:39 PM
Same as for efi, but why on a carb ?
Old Oct 18, 2009 | 07:55 PM
johnnysash's Avatar
johnnysash
sorry did not make myself clear..... it is carb at the moment so the tank is set up for carb with low pressure lines no swirl pot etc. I want to put the high pressure set up onto the van to make it an injection van, what do the boys do who cossie these?
Old Oct 19, 2009 | 08:40 AM
You don't have to have a swirl pot, unless you do "spirited driving"!!
The std outlet if 1/2" or over would be fine, if there is also a return line.
The easiest way would be to fit the injection tank though, piping is easy and can use opa flexy pipe to make easier.
I am not sure if the P100 is the same tank as a hatch/saloon etc, but does not have to be cossie just injection 2L ghia etc, xr4i xr4x4.
Old Oct 20, 2009 | 09:02 PM
johnnysash's Avatar
johnnysash
unfortunately p100 tank is different otherwise it would be a bolt up job. also i like a bit of sideways driving.....so swirl pot is deffinately needed!!! the outlet on the p100 tank is tiny!
I have a s2 turbo tank might be a case of cutting and welding and making a hybrid of the two! was just hoping on an easier way really! as welding a petrol tank could be a bit naughty!
thanks
Old Oct 20, 2009 | 09:08 PM
m4tt274's Avatar
m4tt274
is it running the 2.0 pinto still?
Old Oct 20, 2009 | 11:28 PM
Easy welding tanks, just wash out with water first, won't be a problem, but maybe a fuel cell might be easier, though costly.
Old Oct 22, 2009 | 01:20 PM
johnnysash's Avatar
johnnysash
it was running a 2.8 on a carb....but the bloke i bought it off wanted the engine back. i had an old 2.0 pinto injection sierra lump which is gonna go into it... think i will just weld the tank... unless anyone has any smart idea's
Old Oct 25, 2009 | 12:58 PM
johnnysash's Avatar
johnnysash
so no one has any other comments then?
Old Oct 27, 2009 | 04:12 PM
rcdunk's Avatar
rcdunk
i am in the middle of putting a zetec black top in my p100 doing the rear diff to granada cosworth too
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
