amal valve question
ok as part of me cleaning the engine bay up some im replacing the amal valve pipes with blue vacum hose but...........
one of the hoses from the valve goes into the induction kit and the new bigger filter doesnt have a erm .......hole
where does the pipe go once ive put the new filter in ?
cheers...................matt
I noticed yesterday on my S1 that the amal valve has no pipes fitted to it at all. Any ideas on why? Always thought that they had to be fitted..but it runs good without..so what do they do? And what do the valve do if they aren't fitted?
on a cossie, it'll be fine
only matters on matered air systems like Escort RS Turbos and small turbo esccossies
the boost will rise the airbox acts as a restrictor
mine rose from 15 to 20 held
detted its bollocks off
depends how its jetted of course
mine was a turbosystems stage 1 setup at the time
i had to fit this pipe to slow down the amount of air the valve was bleeding away.....
what the fook that got to do with owt jim lad
on a cossie it's map based, so it doesnt matter if any air goes amiss...
same reason you cant run "normal" dumpvalves on ERSTs ST Esccos etc. they just dont like leaks
altho its such a tiny leak it really makes fack all difference... lol i ran my old TT (metered system) without bleeding the air back in quite happily... lol but then that car was held together with gaffer tape and cableties
i know why jim, i was taking the piss as thats the wrong end of the stick, when matt said wont it upset something i read it as boost upset not fuel upset
but then i knew the answer to the question
