Why is there no water cooling going to my turbo
Old Oct 15, 2009 | 07:51 AM
camo1980's Avatar
camo1980
Default Why is there no water cooling going to my turbo
Hi I have just got my g reg escort rs turbo and noticed that the top hose from the rad has a small hose coming off it but it has been blanked of I take that it would have gone to the turbo but no point on the turbo to put the cooling hose to it can some one give me some help thanks
Old Oct 15, 2009 | 07:54 AM
carcollector's Avatar
carcollector
cause not all turbos are watercooled m8
Old Oct 15, 2009 | 08:05 AM
mk1trb's Avatar
mk1trb
Boost Junkie
must have a series 1 turbo on it, there oil cooled only
Old Oct 15, 2009 | 12:18 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
+1.. The same like me. You have a S1 turbo..
Old Oct 15, 2009 | 12:20 PM
carcollector
my R5 gt turbo was like that....never had an issue
Old Oct 15, 2009 | 04:45 PM
studabear's Avatar
studabear
my cabrio's like ths too
Old Oct 15, 2009 | 04:47 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
i have the holes for water cool but dont use it just oil is that bad
Old Oct 15, 2009 | 05:36 PM
atti's Avatar
atti
mines like it to,it will be ok just let it run for a bit after use so it cools down.!
Old Oct 15, 2009 | 05:42 PM
SteveXR2T's Avatar
SteveXR2T
!! Give me a break !!
on my old S2 i put a S1 turbo on it and i just blanked off the two hoses and it was fine
Old Oct 15, 2009 | 07:05 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you don't need water cooling, but after a session you need to let the engine idle to get the turbo to cool propely otherwise you will have internal turbo damage.
series one turbos have a bigger oil capacity as they don't have water cooling, so don't suffer hot switch off the same.
use the water cooling if you can, but beware it can affect the cooling systems efficiency.
Old Oct 15, 2009 | 08:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As above its fine just let it cool down to avod heat soak in the turbo, before switching off.
Old Oct 15, 2009 | 09:02 PM
gaz s1's Avatar
gaz s1
i always thought ford put the s2 with water pipes to the turbo to improve warm up times from stone cold?
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
robbo9006
11
Sep 1, 2015 02:10 PM
Aug 19, 2015 06:25 PM
