RS1600i parts freshen up
This winter I will start with my RS1600i resto and hopefully its finished before spring begins. Needs a whole list to be done, new front, wings, back end of the car etc. Underside of the car needs to be painted and stripped down. But now iam busy with freshen up all the parts i have.
Here some pictures from different parts... before and after
Made some RVS holders to mount them;
painted them silver:
Over the years i collect a lot of stuff, so i have spare RSi head and complete spare engine. Which iam rebuilding at moment, here some pictures of the lose head i have
Complety resprayed, cleaned and flatten and everything is measured if it still within the marges
it looked like this
it looked like this
At the beginning of january I began with my spare complete engine, it was stored for many years and after I Bought it in 2010. I thought it would be time to start with this engine
first i cleaned the outside with high presure washer then i stripped it back to this
So then it was time to bring the head away to the company which will check the head etc.
and time to paint some of the parts
exhaust in high temp paint
gearbox
gearbox
Thxs for comment
I Have allready more parts finished this week
Had to weld this item but turned out great
Bought some new stuff which is hard to become or way to expensive
this you dont see that often, bargain on ebay
new core plugs for cvh engine from Burton
This one have still to be done
done a few things today start with painting the inlet.
RSi part number on the inlet original thing
After that i started with engine block itself i had painted it allready
Just hang the engine on the standard just weighs a few pounts
then it was time for oil pump completely stripped it
I have a repair kit for oil pump but there is no need to use is. Was all fine inside big relief
Time for little update
2 nieuwe rubbers gehaald voor warm-up
the head
now with bobine and for the good eyes among us 3 cables, but got a brand new set in box...
Tonight it was time to get closer look on the cvh block, damn how nice and easy one is that
anybody an idea if this is high or low mileage wear or not?!
it are just still the standard main bearings which still are tide fit
the head
All of the parts are looking great!
Is the gearbox you have restored a genuine RS1600i?
Has yours got the hole for the ignition sensor in the housing?
Would you mind posting some more photos of it from different angles as I am trying to identify my gearbox.
Keep up the good work
James
James
Thxs for reply mate.
Dont know exactly if its an original RSi box but on the early type number of 81TT and the way the sensor hole is drilled i should think its an original one.
Because the gearbox which was in my own car the hole is drilled in XR3(i) box afterwards. I have no picture of that at the moment or it have to be in my other topic
Thanks for the photo. You are very helpful. I have two gearboxes. One has extra webbing which i think means its s1 turbo but would like to make sure.
There is a way you can check for sure that you have an original gearbox. Take the end cover off to reveal 5th gears. I have reference to the number of teeth on each gear. 5th gear was unique to rs1600i. All you have to do is count the teeth. James
Mc5506
Oct 5, 2015 09:57 PM
