ST24 hesitation?
Old Oct 14, 2009 | 06:49 PM
matts1's Avatar
matts1
Default ST24 hesitation?
Hi all,
my mate called, he said his 'R' reg ST24 has hesitation when he accelerates, like it is holding back or not firing properly.
I haven't been in the car to see exactly what it feels like but can anyone suggest the most likely cause?
Thanks
Matt
Old Oct 14, 2009 | 07:39 PM
kyle_st200's Avatar
kyle_st200
Could be the inlet manifold runner control dude. Thats what opens up the secondries in the inlet,quite a common problem. Also come across the idle speed control valve "mooning"
matts1's Avatar
matts1
tinternet suggesting...
inlet manifold runner control, its the grey little box that opens your secondaries, it sits under the black plastic pump cover which says duratec v6 24 valve
likely cause?
Old Oct 14, 2009 | 07:48 PM
kyle_st200's Avatar
kyle_st200
Ye thats it dude,Ive known a few ST's to need them. They pack up due to the heat from the engine so alot of people relocate them to under the battery
Old Oct 14, 2009 | 07:51 PM
matts1's Avatar
matts1
sorry, missed you inbetween post.
if it is playing up will a relocation solve it or will it be a case of a new one?
If new, are they costly and hard to fit??
Matt
Old Oct 14, 2009 | 07:54 PM
kyle_st200's Avatar
kyle_st200
If its packed up then I would say you need a new one but Id relocate it when you go to fit it. Piece of piss to replace dude.
Old Oct 14, 2009 | 07:59 PM
matts1's Avatar
matts1
good stuff, guessing no point in getting one off a breaker as may well be fooked? will have to check out what ford want for one - ouch!!
cheers for the help fella, much appreciated.
Old Oct 14, 2009 | 08:01 PM
louie1's Avatar
louie1
Hi, my dad had the same trouble with his and was told by fords after a diagnostic that it could either be the cat's knackered or the imrc valve as stated above. but they prone to head gasket failure,does it make any funny ticking noises on pull away?
Old Oct 14, 2009 | 08:02 PM
kyle_st200's Avatar
kyle_st200
Im sure its about Ł150 at ford but that might be fitted. You should be ok with a second hand one,mine on my ST is the original one and has covered 100k so they last quite well. Id go for a used one personally
Old Oct 14, 2009 | 08:09 PM
matts1's Avatar
matts1
cool, and louie, will check the condition of the lump and exhaust systems.
Will let you know how I get on when i see the car tomorrow.
Thanks again peeps.
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Bailes1992
Sep 3, 2015 02:17 PM
Mark Mawson
Aug 31, 2015 07:09 PM
Bailes1992
Aug 16, 2015 07:14 PM
