Okay - so how do you go about wiping EVERYTHING on the PC?
Old Dec 25, 2004 | 01:41 PM
Thrush's Avatar
Thrush
Irritating c........
Default Okay - so how do you go about wiping EVERYTHING on the PC?
Now we got the new PC set up and running downstairs, I'm thinking I might just completely wipe this PC (old shitty thing that it is) and start over completely new and install XP that came with the new one (I guess you can do that right? Got the XP start up CD, so should be able to install that on this PC right?)
So how do I actually go about wiping everything on this PC, including operating system (Win 98 SE) and starting a fresh?
Old Dec 25, 2004 | 01:44 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
What ive done in the past to wipe a HD is plug it into another PC as a secondary drive n wipe the fucker.
Im sure theres a better way tho, maybe
Old Dec 25, 2004 | 01:51 PM
Thrush's Avatar
Thrush
Never thought of that Steve - would be interested tho to see what others have done.....
What I don't get tho is if I wipe it clean and bare - how the feck to I install an operating system
Old Dec 25, 2004 | 01:53 PM
Graceland's Avatar
Graceland
Team HOTHOT!
make a dos boot disc with the format command on it and fdisk command aswell
boot from this disk then when u get a command prompt type "fdisk c:\" without the "" bits tho. follow the instructions and then format the disk - the lot is wiped
or if you want to do a really nasty format, go into the bios menu and do a "low level format" on the disk - altho this is only reccomended if thereeare failed sectors and clusters on the drive.
best o luck
Old Dec 25, 2004 | 01:54 PM
Graceland's Avatar
Graceland
Team HOTHOT!
and to re-install everythingm create an ioerating system start disk
Old Dec 25, 2004 | 01:59 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Or use a REALLY strong magnet
Old Dec 25, 2004 | 02:00 PM
Graceland's Avatar
Graceland
Team HOTHOT!
or a nuclear bomb
Old Dec 25, 2004 | 02:02 PM
Thrush's Avatar
Thrush
Okay..... I have no idea what you jsut said tho Paul
Old Dec 25, 2004 | 02:04 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Old Dec 25, 2004 | 02:10 PM
Graceland's Avatar
Graceland
Team HOTHOT!
when you turn the pc on, about 2 seconds after keep pressing the "delete" key - this will take you into the BIOS menu - look round in there untill you find something that says "low level format HD" and click yes :P
that gets rid of the lot
Old Dec 25, 2004 | 02:11 PM
svony's Avatar
svony
As Graceland said or you can try Wipe Drive Pro, works great for me.
Merry Christmas...
Old Dec 25, 2004 | 02:14 PM
DanRSturbo's Avatar
DanRSturbo
Right, if you want to put Windows XP back on it, then load the xp disc into the drive, and then restart the pc, it should boot off the cd, during the 1st steps it ask's you if you want to format the drive, to which you say "YES".
The data recovery software I have here can recover data even after 10 low level dos formats
Old Dec 25, 2004 | 02:15 PM
Thrush's Avatar
Thrush
I never press delete when I turn PC on tho Paul
Whats this Wipe Drive Pro?
Old Dec 25, 2004 | 02:16 PM
Thrush's Avatar
Thrush
Dan - this ain't got XP on it at mo - has 98 SE, but I would want to put XP on since I got it on CD...
Old Dec 25, 2004 | 02:47 PM
R4N SS's Avatar
R4N SS
thrush can ur old pc handle xp tho? If its om win98 i think it will struggle - prob best to stick win2000 on it.
and you can format as per DanRSTurbo instructions
Old Dec 25, 2004 | 02:54 PM
Jim Galbally's Avatar
Jim Galbally
kmatt, do what dan says.. by far the simplest option! everything else people are suggesting are the LOOOOOONG ass ways of doin it
ps you can do what dan says on 2K and XP
but if youre putting win98 back on then you need to do it by hand...
my personalpreference is to run FDISK.EXE in dos and take option 4 to remove partition (making the drive effectively blank as far as the PC is concerned) then run 98 setup... durting the process it will re-partition and format the drive for you anyway
Old Dec 25, 2004 | 03:03 PM
Taps's Avatar
Taps
Shouldnt be a problem there Liver Boy ya expert at doing it by hand
Old Dec 25, 2004 | 05:02 PM
Thrush's Avatar
Thrush
Taps - feck off I didn't get a banjo for xmas
So Jim/Dan - are you saying that I don't need to delete the HDD first, just load in the XP disk and boot up, and choosing the option to "format" it will remove everything and then install XP as the OS?
Old Dec 25, 2004 | 05:03 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
buy a new one, and throw the old one out the window
Old Dec 25, 2004 | 05:26 PM
Billabong's Avatar
Billabong
No, not necessarily. IF it's a dell or certain other makes, the OS will only install on that make. Plus, if XP's already on your new computer, it ain't gonna activate twice (as in on two different PC's).....
Plus, depending how old your PC is, it may not be happy running XP.
Old Dec 25, 2004 | 05:38 PM
Thrush's Avatar
Thrush
The old PC is an ARIES, and looking at the XP disc it does have Dell written on it a few times, so maybe I should stick with the Win 98 SE that's already on here.....
So if I'm gonna re-install 98, what do I need to do to wipe and re-format?
Old Dec 25, 2004 | 05:41 PM
R4N SS's Avatar
R4N SS
thrush just stick the fookin disc in and reboot.
then it will ask you if you want to remove the partition, say yes and follow the onscreen prompts.
Old Dec 25, 2004 | 08:09 PM
Jim Galbally
it really is THAT fookin simple
bill, he bought his PC off ebay so its likely his disc is a copy anyway
Old Dec 25, 2004 | 09:26 PM
Thrush's Avatar
Thrush
No they ain't jim I bought it off a seller on ebay, but it was shipped to me directly from Dell
155lee
Oct 24, 2015 11:11 AM
Dirty Harry
Aug 2, 2005 02:37 PM
Thrush
Computers, Consoles and I.T.
18
Jun 7, 2005 09:49 PM
Big AL
May 18, 2005 03:13 PM
