what spark plugs for 300hp zvh??
Old Oct 12, 2009 | 07:56 PM
jaiscossie's Avatar
jaiscossie
Default what spark plugs for 300hp zvh??
What you guys using on high powered rst's? The car is a 2.1zvh...
Old Oct 12, 2009 | 08:07 PM
muz's Avatar
muz
Wye Valley Hardcore
Motorcraft 701c or NGK BCR8ES
Old Nov 9, 2009 | 07:57 PM
jaiscossie's Avatar
jaiscossie
Anyone else??
Old Nov 9, 2009 | 08:03 PM
rstdave's Avatar
rstdave
Big turbo escort cosworth plugs for me, pp8's.....was advised to use these years ago and never had any issues whatsoever.
Old Nov 9, 2009 | 08:05 PM
jaiscossie's Avatar
jaiscossie
Are these different to Ford 071 cosworth plugs then?
Old Nov 9, 2009 | 08:52 PM
rstdave's Avatar
rstdave
Yes they are.....071's are cheaper though i think.
Old Nov 9, 2009 | 09:23 PM
Zetecfiesta's Avatar
Zetecfiesta
recomend both of them, had them in my car no issues with either!
Old Nov 10, 2009 | 09:32 AM
sas's Avatar
sas
should be good!
I use NGK BCP7ES or BCP7EVX on mine.
Old Nov 10, 2009 | 10:19 AM
JesseT's Avatar
JesseT
701 replaced the 071
Old Nov 10, 2009 | 10:27 AM
muz's Avatar
muz
Wye Valley Hardcore
Other way round. The 071c replaced the 701c
Old Nov 10, 2009 | 10:37 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
this man is right and they're good enough for a decent level of tune, but for big money better ones are out there.
Old Nov 10, 2009 | 11:08 AM
Tank Mike's Avatar
Tank Mike
denso itv24 are really good
Tank Mike's Avatar
Tank Mike
sorry just seen its a zvh not a zetec turbo
Old Nov 10, 2009 | 02:00 PM
mk1trb's Avatar
mk1trb
Boost Junkie
701's or ngk bcpr8es though i find the spark gets blown out on ngks
Old Nov 10, 2009 | 02:04 PM
Neil@FastFord's Avatar
Neil@FastFord
If you are doing a ZVH, listen to this fella-
Old Nov 10, 2009 | 02:09 PM
RSTurboSI's Avatar
RSTurboSI
They'll need re gapping, i gap'ed mine at 60.30 or 06.30 on the old fealers. never had missfire since, done the same again this time when they was blowing on boost, no problem now.
Old Nov 10, 2009 | 02:35 PM
mk1trb's Avatar
mk1trb
Boost Junkie
didnt think of that lol, dopey sod
Old Nov 10, 2009 | 02:52 PM
RSTurboSI's Avatar
RSTurboSI
Its the simple things people forget about, hay when someone else has a problem i advise them, when i have a problem my brain just totaly wipes out what i know
On sunday went over to a mates to finish off my RS Re-wire and sort the boost out, over boosting.
So once mine was sorted i moved it from the back to the front of his drive. we wanted to wash all the oil and hand marks from the S2 hes rebuilding, lets just say the car started and was fine yeasterday, just left it after it ran and then sunday it wouldnt fire up.
After going from one point to the other it wouldnt start to a point where he got rather stressed, left the battery on charge and stiped down the old fucked shell to fund parts for the new one.
he got stressed again as it wouldnt fire up, as he went kicking and swearing i removed the plugs, cleaned up some spair ones i had in the RS, re-gaped them and place them back in, shouted him over and told him to crank the fucker up, and bingo! Fired.
NGks dont always come gaped correctly, there not Gen plugs there after market ones.
if there blowing out just gap them a little smaller, like .30 or something and that should sort the missfire problem
Old Nov 10, 2009 | 06:09 PM
jaiscossie's Avatar
jaiscossie
Does it matter which ones out of these buddy? This surprised me as always thought motorcraft was the way to go with plugs...
Old Nov 10, 2009 | 06:34 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i use motorcraft 071c's in my zvh, never had an issue, i checked gapping to, so all set to 0.7mm
Old Nov 10, 2009 | 06:52 PM
jaiscossie's Avatar
jaiscossie
^^ what power/ boost yours making mate?
Old Nov 11, 2009 | 08:23 AM
sas's Avatar
sas
should be good!
Ones platanum, ones just standard. Find the one that works best in your engine?
I found the standard one started to go a little splutterly over 25psi but the platnum takes 29psi no problem from my GT30.
Old Nov 11, 2009 | 09:08 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've run 14 psi with them without problems, never had more than that out of car.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
