Fiesta Losing Water????
Old Oct 12, 2009 | 06:12 PM
Shep_Cobain's Avatar
Shep_Cobain
Default Fiesta Losing Water????
Basically my fiesta RS Turbo doesnt overheat or anything but the header tank is always empty after a journey.
If i undo the cap slightly when warm the water does bubble up so i no its completely escaping.
I have just filled coolant up to the max mark. Drove to my mates and took him out for about 30 mins ish. After the car has stopped and cooled the header tank is empty again....?
any ideas.
The oil cap has no mayo in it etc.
Old Oct 12, 2009 | 08:58 PM
Shep_Cobain
i dont think its headgasket as its not smoking ....
Old Oct 12, 2009 | 09:09 PM
studabear's Avatar
studabear
you have prob got a leak, do you know anybody with a pressure tester??
any sign of coolant under the car or damp footwells (heater matrix leak)
Old Oct 12, 2009 | 09:13 PM
Shep_Cobain
the heaters dont get warm in the car.... and no smoke from the exhaust etc.
MSD had it 3 days ago and on the report said there is a small leak somewhere at the front of the engine....?
Old Oct 12, 2009 | 09:45 PM
studabear's Avatar
studabear
either top it up and let it run while looking for the leak or see if you can get it pressure tested to find the leak, if its a visible lek it shouldn't be anything major
maybe ring msd see if they can tell you what was leakin?
Old Oct 13, 2009 | 06:59 AM
Chris69's Avatar
Chris69
I would say you need to get the system upto pressure and then leave the cap on and look for leaks.
If MSD have had it and report a small leak then surely you can contact them and get more details.
Old Oct 13, 2009 | 07:13 AM
Shep_Cobain
UPDATED:
Last night i filled the expansion tank all the way, well just over the max line.
Checked this morning and empty.... no visible leaks though and the car hasnt been started.
Old Oct 13, 2009 | 09:13 AM
studabear's Avatar
studabear
its gotta be going somewhere, if you can't see a external leak perhaps
remove your spark plugs and see if any of them look washed
Old Oct 13, 2009 | 09:18 AM
AJC's Avatar
AJC
probably a loose hose. Put a pressure tester on pal
Old Oct 13, 2009 | 09:59 AM
S1 Combi's Avatar
S1 Combi
As already metioned,are the footwells damp? if there is nothing under the car then it would suggest a leak inside the car,my heater matrix is leaking very slightly so am havin to top up occasionally,im just waiting on a new one
Old Oct 13, 2009 | 10:00 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it could be a core plug, i had the tiniest of weeps from the one behind the cam wheel, eventually it became more apparent.
Old Oct 17, 2009 | 01:38 PM
Shep_Cobain
right found the leak!
Its coming from the read of the head, underneath inlet manifold area rusty/brown water is spraying from that general area.
Will try and get a picture if i can....
Old Oct 17, 2009 | 02:06 PM
studabear's Avatar
studabear
check the hose which runs to the middle of the underside of the inlet first then
Old Oct 17, 2009 | 04:30 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
probably just a split pipe to be honest then.
Shep_Cobain
ok mate, then any ideas after that?
Mark RS
Oct 12, 2015 06:01 AM
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
