Low biting point :(
Old Oct 12, 2009 | 04:21 PM
haz87's Avatar
haz87
Default Low biting point :(
I've got a VERY low biting point, literally as soon as you let off the floor
Replaced quadrant and pawl on pedal
Replaced clutch cable
The quadrant and self adjuster is working spot on.
I have tried whacking spacers along the clutch cable to triple check that there is no stretch (or the new ones are too long etc)
And still the low biting point remains. So this says to me clutch or release bearing. Any other ideas? And what could have gone wrong clutch wise?
It still goes through all the gears perfectly. Its just very hard to get into gear but that might be because of the bite point as well....
Old Oct 12, 2009 | 04:25 PM
darrenb16two's Avatar
darrenb16two
New clutch mate!
Old Oct 12, 2009 | 04:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sounds like the quadrant is faulty, if the biting point is low, then it doesn't mean a worn clutch, the opposite infact.
when you only need to breathe on the pedal at the top indicates clutch worn.
Old Oct 12, 2009 | 04:31 PM
haz87's Avatar
haz87
But as i've said above the quadrant is working perfectly. The old one was in top condition as well. I simply removed it and put a new one in due to the fact i had it all out and i dont ever want to have to piss about with the pedal box ever again,lol
Old Oct 12, 2009 | 04:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not the clutch......... quadrant too small, cable too long, or clutch arm (on gearbox) has been moved round on it's splines.
Old Oct 12, 2009 | 04:38 PM
haz87's Avatar
haz87
Quadrant is exactly the same as the original! So its really not the quadrant (for once)
The cable is brand new and the same length as the old (which was fine up until last week when this happened)
So i'm 100% sure its not the quadrant or cable. I know mk5/6 escorts clutch arms are prone to twisting/bending. It looks fine externally but that doesn't mean it hasn't moved internally (as per karlos's suggestion)
Old Oct 12, 2009 | 04:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's a strange one mate thats for sure! lol
Be careful driving if it's hard to get in to gear as you'll soon find your gearbox dead.............. i know from experience
Old Oct 12, 2009 | 04:55 PM
haz87's Avatar
haz87
Yer i think i'll be whipping the box off tomorow night. I'm hopeing its just a fooked pressure plate or bearing. The clutch itself must be fine as theres no slipping etc! Bloody cars
Old Oct 12, 2009 | 05:54 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
how long has this problem been around, did you alter anything recently before the problem started?
sounds like cable has slipped off quadrant, i know you say it is perfect but it's not making sense.
the cable is not tensioned enough.
Old Oct 12, 2009 | 08:31 PM
haz87's Avatar
haz87
Only started last week. Hadn't touched anything.
I've whipped the box off this eve and the clutch and pressure plate are totally intact. The release bearing is very sticky and needs a fair bit of force to spin the bearings as well. Don't know if this is whats caused it
Old Oct 13, 2009 | 07:42 AM
jonny s2's Avatar
jonny s2
is it not a weak pressure plate, i thought when it was a high biting point that it was shot
Old Oct 13, 2009 | 10:02 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
go back to the quadrant etc, make sure everything is sat how it should be.
as above a worn clutch means a high biting point.
Old Oct 13, 2009 | 01:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Weak pressure plate would just make it slip easier.
Old Oct 13, 2009 | 11:09 PM
botters's Avatar
botters
competant bodger
sounds like clutch to me you dont alwways get slipping from a knackered clutch mate and also biting point can be very low or very high with a knackered clutch it all depends on the vehicle, clutch type , clutch fault etc... my rs was exactly same fault as yours when i got it low biting and sometimes difficult to select gears , changed clutch and hey presto biting normal and gears easy to select (as easy as they can be for the escorts soup stirrer)
Old Oct 14, 2009 | 06:28 AM
ROB7656's Avatar
ROB7656
mine is biteing at the bottom i thought maybe the ratchet may have slipped! going to buy new clutch and get the pedle upgrade so hopfully i wont have to muck about with the poxy ratchet again
Old Oct 14, 2009 | 02:56 PM
haz87's Avatar
haz87
New clutch fitted and all is well!
Looks like it was a partially collapsed pressure plate
Old Oct 14, 2009 | 03:24 PM
darrenb16two
Thought that would be the case mate. Glad you got it sorted an are back on the road! Unfortunatley lots of sunday mechanics on here giving wrong advice!
Old Oct 15, 2009 | 07:02 PM
botters's Avatar
botters
competant bodger
knew i was right pal!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Tank Mike
Sep 26, 2015 08:07 AM
