zvh oil return best place
As above in the block or the sump.I was supplied two non threaded unions.Ctm engineering didnt do the return as i supplied a non threaded union because they wanted to srew it into the sump.The firm that sold me the unions say just press it into the block.Anyone shed some light.Im getting there slowly
modded top mount for three bolts
Tensioner and waterpump
breather
Blocked breather
New front panel getting a lick of hammerite round the
crossmember
breather
Blocked breather
crossmember
Two people have told you to put it in the STD place it should be, i.e the same place as the ERST block.
Buy the connector from Ford 58p and fit it in the correct place.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
