Lumpy Ford
Old Oct 11, 2009 | 08:56 PM
JimForrest's Avatar
JimForrest
Default Lumpy Ford
My daughters 1.6 Vetec Fiesta has just started playing up when cold. It's fine when warmed up but hunts and nearly stalls when idling straight after starting. Presumably it's the ISCV or auto-choke (if they still fit them). Can I adjust it and where on the manifold is it?
There is a screw which sets the tickover but it doesn't have a head (if that makes sense). It sticks out of one side of the casting against the linkage but not the other (where I would expect the head would be).
Old Oct 13, 2009 | 07:31 PM
The iscv sounds lazy, but can usually be cured by cleaning with carb cleaner, it should be fairly easy to spot having most likely a two wire connection to it, and be cylindrical in shape about 1/2 it's length on the inlet trunking somewhere.
Put the engine details into ebay etc with idle speed control valve, this will bring up piccies showing you what it looks like, then easy to find.
It could also be the lambda/maf at fault, but clean iscv first, it's almost free!!
Billy_RS
16
Oct 11, 2025 09:41 PM
Ford Focus ST Parts for Sale
Aug 28, 2015 01:32 PM
borboyous
Aug 22, 2015 11:17 AM
RockinRein
Aug 19, 2015 07:08 PM
