s2 broke down today. help needed please
Old Oct 11, 2009 | 04:05 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default s2 broke down today. help needed please
basically after i done the thermostat, the car wouldnt start when i did start runnin fine but when it went to idle it would back fire and cut out, then went to start it, while trying to start it, it was back fire loud and not start.
any ideas? it has been perfect for 2 years.
running mfi btw
Old Oct 11, 2009 | 04:56 PM
studabear's Avatar
studabear
have you disturbed any of the ht leads while working in that area?
Old Oct 11, 2009 | 05:00 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
no there all fine, i took each plug out and tested it on the ht lead and got a strong spark,
i think its using to much fuel and not enogh air
Old Oct 11, 2009 | 07:40 PM
neil73's Avatar
neil73
check the breathers and air pipes matey
Old Oct 11, 2009 | 08:56 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
did you knock the breather hose off the metering unit? or caused an air leak ?
Old Oct 11, 2009 | 09:15 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i havent checked the breathers i got it going again, but cut out. ill check breathers tomorro, im aware i need new injectors which is havin done in 2 weeks time
mk22door
49
Mar 26, 2022 07:15 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
col93saphcos
Aug 7, 2015 03:21 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
