Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
Small bits needed, Cosworth
Old Oct 10, 2009 | 09:35 PM
RS-Stian's Avatar
RS-Stian
www.fordclubnorway.no
Default Small bits needed, Cosworth
1. I need two of the following clip that sits between the two bolt holes to the front crossmember on a saff Cosworth (engine bay).
Finis code: 1648221. No longer available at Ford.
Does anyone has a couple of new ones for me?
2. Special bolt that fasten the air filter box to the arch which also is a holder for the turbo heat shield. Anyone has a complete one as mine broke during disassembly?
Old Oct 22, 2009 | 06:49 PM
RS-Stian's Avatar
RS-Stian
BUMP. Anyone? Here is a pic of the special bolt I need.
Old Jan 5, 2010 | 04:12 PM
RS-Stian's Avatar
RS-Stian
BUMP. Bolt is fixed but i still need the clips on the pic above. It should be the same on a non-cossie Sierra.
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
