Does any one no water waterhose goes where on a 4x4 cos
Sorry but car been apart for so long and struggling to run hoses correctly and want to double check i put them back ok
cheers
cheers
bit ov a od one mate
well click on the link and theres all the book you will ever need
http://www.siipicossu.com/manuaaleja/manuaalit.htm
was basically looking to what hose the angled hose of water pump goes to, at min i got connected to the metal pipe bolted to the radiator that runs across to bottom of the rad and up the header tank side and straight to bottom hose of header tank, and the top header tank hose i have running to the turbo, just wanted to check this is ok
cheers
cheers
Mark RS
Oct 12, 2015 06:01 AM
