escort 1.8td pump problem
Old Oct 9, 2009 | 05:18 PM
lockstock169's Avatar
lockstock169
Default escort 1.8td pump problem
got a escort 1.8 td with a leaky pump,,,, its NOT any of the joints or slip on connectors ,nor the fuel return pipes . But have seen a very slow trickle of fuel when running, from the side of pump that faces block pump has coded box on top ,,,,,, any ideas
Old Oct 9, 2009 | 11:05 PM
cabriolet's Avatar
cabriolet
coded box? what year is it has it still got the anti tamper shield on it have known the stop solenoid under the shield to come loose fella
Old Oct 9, 2009 | 11:34 PM
lockstock169
hello mate ... its a 99 v and yup still got anti tamper on,,,,,,,, many thanks will look in morn appreciate it
Old Oct 9, 2009 | 11:38 PM
cabriolet's Avatar
cabriolet
no probs fella bastard thing to get to but it can b done in the car
Old Oct 10, 2009 | 01:50 PM
lockstock169
yup youre right,,, bastsrd of job ,,,, but out now and guess what ..no sight of a leak ,,,solly is tight all other connectors good,,,just gonna keep looking ,,,
but many thanks 4 your advice my friend appreciate it take care , will let you know if i find (when) i find it
ken
Old Oct 10, 2009 | 05:13 PM
cabriolet's Avatar
cabriolet
ok fella good luck sounds like yr gonna need it
Old Oct 10, 2009 | 06:05 PM
lockstock169
and i thought you would like a day in sunny southend LOL
Old Oct 11, 2009 | 08:46 PM
lockstock169
done,dusted n up n running,,,, where inj pipes connect to pump ,,,,,,,, cracked new pump on sorted thanks once again
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
