rs turbo engine focus
Old Oct 7, 2009 | 05:57 PM
yhyhboi's Avatar
yhyhboi
Default rs turbo engine focus
will a mark 4 series 2 escort rs turbo engine fit in a focus if so will it bolt in or is it hard work
Old Oct 7, 2009 | 05:58 PM
m4tt274's Avatar
m4tt274
ZVH
Old Oct 7, 2009 | 06:00 PM
yhyhboi's Avatar
yhyhboi
not good wit engines so need some advice if it can be ill take it somewhere engine is given to me by friend want a turbo in it
Old Oct 7, 2009 | 06:05 PM
m4tt274's Avatar
m4tt274
The RST engine is known as a CVH and focus's have zetec engines. if u use the zetec bottom end and a CVH top end its called a ZVH and because the block is a zetec it will use the focus gearbox and engine mounts
thats as simply as i can put it
Old Oct 7, 2009 | 06:11 PM
yhyhboi's Avatar
yhyhboi
so is it a easy job then please
Old Oct 7, 2009 | 07:49 PM
maccas1985's Avatar
maccas1985
As m4tt274 says it will have a zetec bottom end so the mounts should be the same.
Obviously you are going to have to built the zvh up using the cvh head off your rs turbo.
As for ease it will depend on how much knowledge you have on the two engines and also how good your are with a set of spanners.
If you arent there are many good garages about that will carry the conversion out.
Hop this helps you out
Macca
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
