What boost gauge is more popular?
Hi everyone.
Last night was with a mate and we were having a silly play fight over PSI and BAR boost gauges, he uses a gauge in bar and always refers to his car in bar, where as i used a psi gauge and refer to my car in psi.
So what does everyone else use, this is just out of curiosity. In my mind psi something more real, pounds per square inch. Bar?, what a chocolate bar?!lol
I've used both before now and have a BAR one in the cossie.
Scale is -1 to +2 bar and it reads off the scale in both directions
If you're technically minded then you can easily change between BAR and PSI mid conversation and still know what the numbers mean
PS - 2.2 bar FTW
PS - 2.2 bar FTW
From MY experience i always preferred psi in my rst as it was sometimes wanky little numbers of 10 psi which looks
on a 2 bar gauge.
When i grew up and got a cossie i've had bar ever since
on a 2 bar gauge.When i grew up and got a cossie i've had bar ever since
PS - 2.2 bar FTW
PS - 2.2 bar FTW
In my stupidity what is a BAR?
PS - 2.2 bar FTW
PS - 2.2 bar FTW
I doubt it is wrong - compared to the PSI gauge that was there before it is accurate (and that has been tested with a calibarated air supply etc etc)
It was easier to say it reads both sides of the scale for comparison instead of being too detailed
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
