Black smoke ?
Old Oct 5, 2009 | 10:20 PM
stuarth's Avatar
stuarth
Default Black smoke ?
what causes black smoke on diesels,got an old 2.8 td pajero you notice it more at nite with head lights behind you , see it most when u boot it, its got a kind of screetch from turbo when on boost could this be related?
Old Oct 5, 2009 | 10:23 PM
coleman's Avatar
coleman
Always in the background
Normally just unburnt diesel
Old Oct 5, 2009 | 10:26 PM
stuarth's Avatar
stuarth
what causes it to have unburnt fuel though ???
Chip's Avatar
Chip
*** Sierra RS Custard ***
Running rich, its soot.
Petrols do the same to a lesser extent.
Old Oct 5, 2009 | 10:28 PM
whosyadaddy's Avatar
whosyadaddy
seeing as its an old diesel id hazard a guess at a worn or sticking injector, allowing fuel to drip into cylinder.
Old Oct 5, 2009 | 10:29 PM
martysmartie's Avatar
martysmartie
Black smoke as said is fuel but may be your turbo as you say it sounds noisy, so not making the boost, so you are having a richer mixture with the result being black smoke chucked out the back.
Martin
Old Oct 5, 2009 | 10:31 PM
Chip's Avatar
Chip
clogged up air filter can cause black smoking too IME, as less air flows.
1098's Avatar
1098
FIESTAHH
Diesels will kick out black soot when you boot it, as it cleans the system out to an extent.
Old Oct 5, 2009 | 10:34 PM
stuarth's Avatar
stuarth
Martin
its deff got a strange noise from turbo , and only seems to be bad when on boost,like when on kick down to go up hill, its almost like a fan belt screatch, people i have spoke to about it ask if its loosing power but its hard to tell as there slow as shit anyway !
Old Oct 5, 2009 | 10:35 PM
stuarth's Avatar
stuarth
i serviced it mate changed air and fuel filter
Old Oct 5, 2009 | 10:42 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
unburnt fuel.
Ive smoked out a few people when theyve been unwise enough to stand behind my landrover on start up
As has been mentioned, its due to a number of contributing factors
usual service items like airfilter, fuel filter
Worn items like fuel pump, injectors.
Also things like a cracked or small leak on a turbo vacum hose, even a pin hole size can have an effect.
I wouldnt worry too much, unless is very heavy smoke. Like those old transits you see doing a james bond smoke screen down the dual carrigeway.
If its just on start up and under heavy load dont worry. Even brand new diesels will puff away if you floor them.
Old Oct 5, 2009 | 10:52 PM
stuarth's Avatar
stuarth
thanks guys
Old Oct 6, 2009 | 07:20 PM
Diesels put out particulates that petrol engines don't, the light of a car headlight illuminates this really well, will happen when all is well, as well as when overfuelling, happened on mine even when on 100% bio, no turbo, no overfuelling.
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
