Forge dump valve probs!
Old Oct 5, 2009 | 06:03 PM
lmmrst's Avatar
lmmrst
Unhappy Forge dump valve probs!
Hi guys i need your help on this one! Hubbys just bought me a forge dump valve for my mfi series 2 escort rs turbo and my car wont run with it!!! It wont tick over!!AHHHHHHHHH it runs like a bag of shite is there a reason for this?? Do mfi and efi vary??
Cheers in advance!
Old Oct 5, 2009 | 06:13 PM
Alvyn's Avatar
Alvyn
yea put a twin piston type one on NOT the single one you've just fitted!
Old Oct 5, 2009 | 06:21 PM
KSA-Cossie's Avatar
KSA-Cossie
As above.
Old Oct 5, 2009 | 06:27 PM
lmmrst's Avatar
lmmrst
Guys apparently it is a twin piston! HELPPPPPPPPPPPPP
Old Oct 5, 2009 | 06:36 PM
KSA-Cossie's Avatar
KSA-Cossie
Send it back rst's run better without one anyway.
Old Oct 5, 2009 | 06:42 PM
Alvyn's Avatar
Alvyn
take it off and look up the tube part and see if there's a rod inside!
Old Oct 5, 2009 | 06:54 PM
lmmrst's Avatar
lmmrst
No rod mate!
Old Oct 5, 2009 | 06:59 PM
Alvyn's Avatar
Alvyn
No rod mate!
then thats a single piston type then which = NO good for you!
Old Oct 5, 2009 | 07:01 PM
lmmrst's Avatar
lmmrst
Cheers mate will pop it back to my chum at forge! If i get a dual will it work?? Cheers lisa
Old Oct 5, 2009 | 07:07 PM
Alvyn's Avatar
Alvyn
yep 100%
think this is the type you need to get Forge 6-bolt type piston dump-valve
Old Oct 6, 2009 | 06:08 PM
lmmrst's Avatar
lmmrst
yep 100%
Cheers mate all swapped over and car runs but havent taken it out yet!! Cheers kindly for info matey! Lis x
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
richierich1986
Sep 18, 2015 03:29 PM
