s2 boosts fine in 3rd,4th,5th but 2nd takes a while
Old Oct 5, 2009 | 05:40 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default s2 boosts fine in 3rd,4th,5th but 2nd takes a while
as above in 2nd my turbo take longer to kick in then 3rd,4th and 5th
Old Oct 5, 2009 | 05:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It will do! lol
The engine is under less load and for a shorter period of time, perfectly normal.
Old Oct 5, 2009 | 05:46 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Really, funny how i didnt notice it before mate? i thought something was wrong, in 2nd it is on full boost at 4000rpm just under, the rest of the gears is 3000rpm,
what do you mean by load?
Old Oct 5, 2009 | 08:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah thats normal, i'm not even sure if mine makes full boost in 2nd would lose traction first!!
Because it's a lower gear the engine is under less load/stress and so doesnt flow/breathe as much as in higher gears, bit like cycling a bike up a steep hill in 1st then trying the same hill in 21st gear! Your legs wil be under a lot more stress/load so you'll be breathing heavier lol ........same goes for your engine as you go up through the gears.
Old Oct 5, 2009 | 09:53 PM
ricky_2006's Avatar
ricky_2006
turbo lag
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
CLIVE
Oct 2, 2015 12:58 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
RsS2daz
Aug 14, 2015 05:26 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
