Air injectors
Old Oct 5, 2009 | 08:05 AM
Criscsw's Avatar
Criscsw
Cosworth passionate
Default Air injectors
Hi guys....
During my navigation on this forum, i can see that in england, used a lot the air injcetors system for boost control....
It's a very interesting system....but how does it function?! It's very strange for me.....can you help me?!
Cheers.
Cris
Old Oct 5, 2009 | 10:13 AM
oldford's Avatar
oldford
First of all, you can't use this system without changing your eprom!
Air injectors work exactly opposite to the normal function of boost control.
If the injector is closed there's no pressure to the waste gate and the turbo is allowed to make as much boost as possible.
If you want to decrease the boost you open the air injector a bit and apply some boost to the waste gate, thereby opening it.
So, the higher the duty cycle on the air injector, the lower the boost is.
Normal boost control is the higher the duty cycle, the higher the boost is.
The advantage is that less air is blown off than with normal boost control.
For motorsports applications (with restrictors) this is very nice to have.
On an unrestricted turbo the gains are very small (if there's a gain).
Old Oct 5, 2009 | 11:02 AM
Criscsw's Avatar
Criscsw
Cosworth passionate
Perfect.....
So, i must to install an a remapable ECU like Pectel, Mek Tronic or MoTeC.....
Old Oct 5, 2009 | 11:05 AM
KSA-Cossie's Avatar
KSA-Cossie
No MSD can do this on L8
Old Oct 5, 2009 | 11:17 AM
oldford's Avatar
oldford
Criscsw, where do you want to use it for? Rally group A with restrictor or road use without restrictor? Any tuners in Italy that can remap the standard Weber-Marelli ecu's?
Old Oct 5, 2009 | 12:21 PM
ludo's Avatar
ludo
cris want to use on road use
ciao cris
in italy the air injectors dont know how they are...
what ecu can we use to do it?
Old Oct 5, 2009 | 01:06 PM
Criscsw's Avatar
Criscsw
Cosworth passionate
Hi Ludo....
Guys, Ludo is one of my best friend!!!
I want to know bettere this system for a road installation/use with a TD05HL.....
In Italy only some tuners, can remap the IAW 48P8....but in the future i'll install probably a Mec Tronik MTE2......can i use the air injectors with Mec Tronik?!
Criscsw's Avatar
Criscsw
Cosworth passionate
What's an MSD?!? I don't know it..... sorry....
Old Oct 5, 2009 | 01:09 PM
KSA-Cossie's Avatar
KSA-Cossie
Motorsport developments m8,im gonna run air to air on my new engine.
Old Oct 5, 2009 | 01:16 PM
ludo's Avatar
ludo
Originally Posted by Criscsw
Hi Ludo....
thank you cris!!!
it is a develop of p8 or another thing??
in italy we are in the 8th century about cosworth
(and not only about cosworth...........)
Old Oct 5, 2009 | 01:17 PM
Criscsw's Avatar
Criscsw
Cosworth passionate
So....with only L8 and Motorsport Development, i can run air injectors?!?
WOW!!! That's awesome!!
Old Oct 5, 2009 | 02:06 PM
KSA-Cossie's Avatar
KSA-Cossie
No but they can do it.
Old Oct 5, 2009 | 02:31 PM
Criscsw's Avatar
Criscsw
Cosworth passionate
Perfect!!
Ooohh....England.....i'm loving this country!!!
In Italy with P8, the tuners can run onlu ALS....not double map, or 8 injectors, Launch or else.....
Old Oct 5, 2009 | 03:02 PM
VEEDUBBED's Avatar
VEEDUBBED
Marooona,quanti Italiani in giro sull forum
Old Oct 5, 2009 | 03:20 PM
ludo's Avatar
ludo
aahahahahhaahaha
Old Oct 5, 2009 | 04:04 PM
VEEDUBBED's Avatar
VEEDUBBED
Ludo,beato a te che puoi girare con una cosworth.
Qui a Roma l'assicurazione ti stacca le palle,non parliamone poi dell bollo...
'Sti caxxi di inglesi manco pagano il passaggio di proprietŕ.!
Old Oct 5, 2009 | 06:27 PM
dakunia's Avatar
dakunia
Hi Criscsw, Motorsport Development (MSD) is a company which can do all what You need with Your ECU, P8 or L8. Launch control, Air Injectors, wasted spark conversions and air injector of course. And all other.
More about offer can You find here: http://www.remapping.co.uk
and more about air injectors is here: https://passionford.com/forum/techni...they-work.html
cheeRS
maciek
Old Oct 5, 2009 | 08:13 PM
ludo's Avatar
ludo
cheeRS
maciek
i see all this link this afternoon, it's wonderful how do you work in uk
in italy we don t have nothing like this....
Old Oct 6, 2009 | 06:57 AM
Criscsw's Avatar
Criscsw
Cosworth passionate
cheeRS
maciek
Very compliments for Motorsport Developments.....in Italy this kind of tune, we can only dream.....
It's very interesting, that in UK with a simple L8 or P8, you can do all these things......
Old Oct 6, 2009 | 06:19 PM
The injectors used are used for air control but are in fact CNG injectors developed for Compressed Natural Gas.
The std amal valve is totally capable of boost control also.
A lot of things done on cars are done for either bling reasons or because someone else has done it.
Old Oct 6, 2009 | 06:34 PM
ludo's Avatar
ludo
or because you don t know the best way to reach your goal.....
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
